ishihara johnson crank scrapers #1993444
01/18/16 05:36 PM
01/18/16 05:36 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
ishihara johnson crank scrapers, anyone have any idea of their turnround time?
TIA.
Re: ishihara johnson crank scrapers [Re: Tig] #1993487
01/18/16 06:58 PM
01/18/16 06:58 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
They're not fast about a month or 6 weeks from my experience, but a nice product.
Re: ishihara johnson crank scrapers [Re: Tig] #1993490
01/18/16 07:05 PM
01/18/16 07:05 PM
Washington
madscientist Offline
Washington
It took me about a month to get mine. Certainly worth the wait.
FWIW I bought both the teflon up scraper and the down scraper. I probably wouldn't bother with a non-teflon scraper. And one more thing. Grab a pad and pencil when you call Kevin. Learning from him is like drinking from a fire hose. I can't tell you how many times I have referred to my notes from our phone calls for information. And it's not just about crank scrapers. Very, very smart guy, Kevin is.
Re: ishihara johnson crank scrapers [Re: Tig] #1993548
01/18/16 08:39 PM
01/18/16 08:39 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Had my first one in a week, but for wrong stroke. Second one, about 2-3 weeks. Was worth the wait. Didn't get the Teflon one.
Madscientist: what do you think of the fit on the Teflon one. Wasn't sure if it was worth the extra expense at the time. He sure does high quality work.
[image][/image]
Re: ishihara johnson crank scrapers [Re: Tig] #1993575
01/18/16 09:10 PM
01/18/16 09:10 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I put one in before last season,took about 2-3weeks to get but I told him I wasn't in a hurry,I got the teflon one. lots of work fitting it, but to work correctly that's what it takes. I'm not sorry I got it. very nice quality. Kevin is top notch like Madscientist said.
Re: ishihara johnson crank scrapers [Re: sgcuda] #1993597
01/18/16 09:40 PM
01/18/16 09:40 PM
Washington
Washington
I like the fit on the teflon because it is essentially an interference fit. Way back when I was young and stupid (now it's old and stupid) I had a friend who was big on scrapers (this would have been 1985) and he made me one for my stuff. We fit on that thing for hours and hours. It was a royal PITA. The strange thing was I clearly remember my friend wanting to use something other than steel to make the scraper. Too bad he died in 1986. That guy was way ahead in what he thought. but the teflon is worth the little bit extra money IMO. It's a time saver and I think it is a bit more effective.
Re: ishihara johnson crank scrapers [Re: Tig] #1993615
01/18/16 09:49 PM
01/18/16 09:49 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Ordered in Oct, but this is a one off I guess. 5 inch stroke, 4.84 bore center, Alloy rods etc won't make it easy. Teflon scraper, also getting a windage tray.
Re: ishihara johnson crank scrapers [Re: Tig] #1993620
01/18/16 09:52 PM
01/18/16 09:52 PM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
The one for my 408 took about 4 or 5 weeks to arrive also. I'm very happy with it. As a matter of fact I'm ordering one for my big block build in a week or so.
Ted
Re: ishihara johnson crank scrapers [Re: Tig] #1993626
01/18/16 09:58 PM
01/18/16 09:58 PM
Washington
Washington
Is IJ doing the windage tray for you? I almost popped for IJ doing me a windage tray too but for a DD I figured I was pushing the wife a bit much.
Re: ishihara johnson crank scrapers [Re: madscientist] #1994142
01/19/16 03:54 PM
01/19/16 03:54 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Yep , they're doing the windage tray too. I have a pretty shallow custom sump and use a 3 qt accumulator. This worked fine with the 572 (4.5 x 4.5) motor with a modified stroker Milodon windage tray. The rod bolts hit the windage tray when we swapped it all over to the 655 so we ran all last season without one. We had oil pressure issues, dropping maybe 15 -20 psi to 30 psi when slowing down but the bearings seemed fine. I'd be happier running a windage tray and at the same time thought it would be a good idea to run a scraper on the 5 inch crank.
Re: ishihara johnson crank scrapers [Re: Tig] #1994146
01/19/16 03:57 PM
01/19/16 03:57 PM
Washington
Washington
Are you willing to post some pics of the WT when you get it?? If not I understand. I'd like to see what he comes up with. Kevin is one of the smartest guys I have run into (not just about gearhead stuff either) so it's interesting to try and get my head around why he does what he does.
Re: ishihara johnson crank scrapers [Re: madscientist] #1994155
01/19/16 04:07 PM
01/19/16 04:07 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I won't have a problem if Kevin doesn't. He has posted pics of other trays and scrapers on his website, wouldn't think there will be any problem. Just need to get it here first grin
Re: ishihara johnson crank scrapers [Re: Tig] #2005478
02/04/16 03:16 PM
02/04/16 03:16 PM
Chicago
Lee Offline
Lee  Offline
Chicago
I ordered a teflon big block scraper on Dec 6th. Still waiting. Many calls to them and messages. No return call. Not sure how much longer I will wait to finish up the motor.
Lee
Re: ishihara johnson crank scrapers [Re: Tig] #2010366
02/12/16 08:37 AM
02/12/16 08:37 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Still waiting frown More calls, messages left, emails and still no reply. It's all paid for including shipping 15ish weeks ago just hope everything is OK over there.
Anyone know or hear anything? shruggy
Re: ishihara johnson crank scrapers [Re: Tig] #2010524
02/12/16 04:12 PM
02/12/16 04:12 PM
Washington
Washington
Tig, I sent you a PM.
Re: ishihara johnson crank scrapers [Re: Lee] #2010586
02/12/16 05:53 PM
02/12/16 05:53 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
Originally Posted By Lee
I ordered a Teflon big block scraper on Dec 6th. Still waiting. Many calls to them and messages. No return call. Not sure how much longer I will wait to finish up the motor.
Lee
Lee, you always have something up your sleeve. lol
Re: ishihara johnson crank scrapers [Re: Tig] #2010607
02/12/16 06:17 PM
02/12/16 06:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Anyone have a pic? I have never seen one
Re: ishihara johnson crank scrapers [Re: Tig] #2010626
02/12/16 06:43 PM
02/12/16 06:43 PM
Washington
Washington
There are pics on his web site.
Re: ishihara johnson crank scrapers [Re: madscientist] #2010834
02/12/16 11:36 PM
02/12/16 11:36 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
It took three months for mine.
Long wait, but it fit well.
1974 Roadrunner
1967 Charger
Re: ishihara johnson crank scrapers [Re: Tig] #2012185
02/15/16 01:14 AM
02/15/16 01:14 AM
Chicago
Lee Offline
Lee  Offline
Chicago
Still waiting
I emailed him on Feb 4th and he replyed it was getting shipped. 10 days later and still waiting.
Lee
