ishihara johnson crank scrapers
#1993444
01/18/16 05:36 PM
01/18/16 05:36 PM
Posts: 2,928 A shed in England
Tig
A shed in England
ishihara johnson crank scrapers, anyone have any idea of their turnround time? TIA.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: ishihara johnson crank scrapers
[Re: Tig]
#1993490
01/18/16 07:05 PM
01/18/16 07:05 PM
Posts: 4,457 Washington
madscientist
Washington
It took me about a month to get mine. Certainly worth the wait.
FWIW I bought both the teflon up scraper and the down scraper. I probably wouldn't bother with a non-teflon scraper. And one more thing. Grab a pad and pencil when you call Kevin. Learning from him is like drinking from a fire hose. I can't tell you how many times I have referred to my notes from our phone calls for information. And it's not just about crank scrapers. Very, very smart guy, Kevin is.
[Re: Tig]
#1993548
01/18/16 08:39 PM
01/18/16 08:39 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Had my first one in a week, but for wrong stroke. Second one, about 2-3 weeks. Was worth the wait. Didn't get the Teflon one. Madscientist: what do you think of the fit on the Teflon one. Wasn't sure if it was worth the extra expense at the time. He sure does high quality work.
[image][/image]
[Re: sgcuda]
#1993597
01/18/16 09:40 PM
01/18/16 09:40 PM
madscientist
Washington
Had my first one in a week, but for wrong stroke. Second one, about 2-3 weeks. Was worth the wait. Didn't get the Teflon one. Madscientist: what do you think of the fit on the Teflon one. Wasn't sure if it was worth the extra expense at the time. He sure does high quality work. I like the fit on the teflon because it is essentially an interference fit. Way back when I was young and stupid (now it's old and stupid) I had a friend who was big on scrapers (this would have been 1985) and he made me one for my stuff. We fit on that thing for hours and hours. It was a royal PITA. The strange thing was I clearly remember my friend wanting to use something other than steel to make the scraper. Too bad he died in 1986. That guy was way ahead in what he thought. but the teflon is worth the little bit extra money IMO. It's a time saver and I think it is a bit more effective.
[Re: Tig]
#1993615
01/18/16 09:49 PM
01/18/16 09:49 PM
Tig
A shed in England
Ordered in Oct, but this is a one off I guess. 5 inch stroke, 4.84 bore center, Alloy rods etc won't make it easy. Teflon scraper, also getting a windage tray.
[Re: Tig]
#1993626
01/18/16 09:58 PM
01/18/16 09:58 PM
madscientist
Washington
Ordered in Oct, but this is a one off I guess. 5 inch stroke, 4.84 bore center, Alloy rods etc won't make it easy. Teflon scraper, also getting a windage tray. Is IJ doing the windage tray for you? I almost popped for IJ doing me a windage tray too but for a DD I figured I was pushing the wife a bit much.
[Re: madscientist]
#1994142
01/19/16 03:54 PM
01/19/16 03:54 PM
Tig
A shed in England
Ordered in Oct, but this is a one off I guess. 5 inch stroke, 4.84 bore center, Alloy rods etc won't make it easy. Teflon scraper, also getting a windage tray. Is IJ doing the windage tray for you? I almost popped for IJ doing me a windage tray too but for a DD I figured I was pushing the wife a bit much. Yep , they're doing the windage tray too. I have a pretty shallow custom sump and use a 3 qt accumulator. This worked fine with the 572 (4.5 x 4.5) motor with a modified stroker Milodon windage tray. The rod bolts hit the windage tray when we swapped it all over to the 655 so we ran all last season without one. We had oil pressure issues, dropping maybe 15 -20 psi to 30 psi when slowing down but the bearings seemed fine. I'd be happier running a windage tray and at the same time thought it would be a good idea to run a scraper on the 5 inch crank.
[Re: Tig]
#1994146
01/19/16 03:57 PM
01/19/16 03:57 PM
madscientist
Washington
Ordered in Oct, but this is a one off I guess. 5 inch stroke, 4.84 bore center, Alloy rods etc won't make it easy. Teflon scraper, also getting a windage tray. Is IJ doing the windage tray for you? I almost popped for IJ doing me a windage tray too but for a DD I figured I was pushing the wife a bit much. Yep , they're doing the windage tray too. I have a pretty shallow custom sump and use a 3 qt accumulator. This worked fine with the 572 (4.5 x 4.5) motor with a modified stroker Milodon windage tray. The rod bolts hit the windage tray when we swapped it all over to the 655 so we ran all last season without one. We had oil pressure issues, dropping maybe 15 -20 psi to 30 psi when slowing down but the bearings seemed fine. I'd be happier running a windage tray and at the same time thought it would be a good idea to run a scraper on the 5 inch crank. Are you willing to post some pics of the WT when you get it?? If not I understand. I'd like to see what he comes up with. Kevin is one of the smartest guys I have run into (not just about gearhead stuff either) so it's interesting to try and get my head around why he does what he does.
[Re: madscientist]
#1994155
01/19/16 04:07 PM
01/19/16 04:07 PM
Tig
A shed in England
I won't have a problem if Kevin doesn't. He has posted pics of other trays and scrapers on his website, wouldn't think there will be any problem. Just need to get it here first
[Re: Tig]
#2010366
02/12/16 08:37 AM
02/12/16 08:37 AM
Tig
A shed in England
Still waiting More calls, messages left, emails and still no reply. It's all paid for including shipping 15ish weeks ago just hope everything is OK over there. Anyone know or hear anything?
[Re: Lee]
#2010586
02/12/16 05:53 PM
02/12/16 05:53 PM
Posts: 279 Chicago land, IL
dafixr
Chicago land, IL
I ordered a Teflon big block scraper on Dec 6th. Still waiting. Many calls to them and messages. No return call. Not sure how much longer I will wait to finish up the motor.
Lee Lee, you always have something up your sleeve. lol
[Re: Tig]
#2010626
02/12/16 06:43 PM
02/12/16 06:43 PM
madscientist
Washington
There are pics on his web site.
[Re: madscientist]
#2010834
02/12/16 11:36 PM
02/12/16 11:36 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
It took three months for mine.
Long wait, but it fit well.
1974 Roadrunner
1967 Charger
