M1 intake against a Eddy Victor 383 #1992831
01/17/16 06:41 PM
01/17/16 06:41 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
anyone ever do a comparo between the two manifolds? reason I ask is the M1 comes in a Dominator flange but the Victor does not and I would like to get away from the adapter spacer and run just a full size Dommy spacer. work
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1992890
01/17/16 07:54 PM
01/17/16 07:54 PM
AndyF Offline
AndyF  Offline
If you're running a Dominator carb then the M1 4500 will make more power. If you're running a 4150 carb then it is a tossup. I think the M1 4500 makes more power but it might depend on the combo.
Good luck finding a M1 4500. I don't think they are making them anymore so you have to find one in stock somewhere.
Re: M1 intake against a Eddy Victor 383 [Re: AndyF] #1992934
01/17/16 09:07 PM
01/17/16 09:07 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
I was running an m1 on a 512 with a 1050. bought the victor 383 ported from hughes engine with an adapter and the same 1050. the car went .050 quicker in the 1/8 and .22 quicker in the 1/4. their web sit as a tech article on intakes.
Re: M1 intake against a Eddy Victor 383 [Re: SixDRacing] #1992937
01/17/16 09:12 PM
01/17/16 09:12 PM
Andrews,In. U.S.of A.
67_Satellite Offline
2 seconds in the quarter! That's one heck of a top end charge.Typo error?
Re: M1 intake against a Eddy Victor 383 [Re: AndyF] #1993001
01/17/16 10:56 PM
01/17/16 10:56 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Thank's Andy, I know how you are using a victor to dyno with but was curious about the M1, a buddy of mine has a dom flange M1 that I can use if I want.
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993035
01/17/16 11:59 PM
01/17/16 11:59 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
why not max wegde port your heads
1.39 9.85 - 137 mph
Re: M1 intake against a Eddy Victor 383 [Re: Ari440] #1993079
01/18/16 01:14 AM
01/18/16 01:14 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Summit still lists M1 single plane 4150 and 4500 B intakes on there site. They do not list the M1 single plane std. port RB 4150 and 4500 intakes.
The only Carbs I care about are under the hood!
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993109
01/18/16 02:28 AM
01/18/16 02:28 AM
AndyF Offline
AndyF  Offline
I tested both intakes. The M1 made better power so I switched to the M1.
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993162
01/18/16 05:15 AM
01/18/16 05:15 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No back to back test`s but the Victor was faster in my dart w/the adapter and now being fully ported, I`m sure it would kill the M-1...........
Re: M1 intake against a Eddy Victor 383 [Re: AndyF] #1993203
01/18/16 11:17 AM
01/18/16 11:17 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
sounds like I really cannot go wrong with ether one unless there was a big difference between them.
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993221
01/18/16 11:46 AM
01/18/16 11:46 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I found the standard M1 with the 4500 adapter worked the best - the added volume really helps
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993455
01/18/16 05:55 PM
01/18/16 05:55 PM
In a house near you
Street Monkies Offline
In a house near you
The old Team G 4500 tall top doesn't make the big power numbers on the dyno, but on every combo I've seen it on it seems to run exceptionally well at the track,plus you can pick one up cheap. Just my two cents.
Re: M1 intake against a Eddy Victor 383 [Re: DoubleD] #1993470
01/18/16 06:28 PM
01/18/16 06:28 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
while I am not the brightest bulb in the pack it seem's to me that the dominator flange to 4150 flange adapter is a choke, you go from big to small then back to big, that is the system I have on my smallblock because nobody that I have found makes a dommy flange manifold for a LA smallblock,,if I had a sacrificial manifold that I didn't give a hoot about I would like to take one and weld a plate on it and open it up to a dominator flange size and see what would happen, I know it's been done but I don't have the right equipment to do it,I know, I know, we know a guy.....LOL laugh2
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993751
01/18/16 11:53 PM
01/18/16 11:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Think carb venturi................low speed/high speed haul ass.........I don`t base ANYTHING on dyno #`s except where the timing and wfo afr`s are everything else is to get you CLOSE and make sure there`s no leaks or other problems. Pro-stock are out at TRACKS testing not basing everything on dyno numbers............
Re: M1 intake against a Eddy Victor 383 [Re: Thumperdart] #1993785
01/19/16 12:33 AM
01/19/16 12:33 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
told ya I wasn't the britest bulb, never concidered the venturi effect,and what it could do,,,dam I gave myself a headache. laugh2
Re: M1 intake against a Eddy Victor 383 [Re: dartman366] #1993794
01/19/16 12:42 AM
01/19/16 12:42 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
no typo. it ran 10.29 with the m1, 9.97 with the victor 383. the victor was ported and the adapter was matched to the intake.
Re: M1 intake against a Eddy Victor 383 [Re: SixDRacing] #1994083
01/19/16 02:35 PM
01/19/16 02:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, and SSSOOOO tired of hearing about dyno crap and hp numbers. Dyno world yes, real world no. Do they dyno top fuel motors? NO......Pro-mod NO. Kinda like big cyl. head flow numbers and although impressive, not likely to always be the fastest down the street or track. beer
