Help with cam choice, 499 with -1s
#1992566
01/17/16 02:22 PM
01/17/16 02:22 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
I was planning on going custom, but since I have a summit discount code and plan to place an order with them shortly, I was seeing if there is anything off the shelf that would work well.
499" low deck, 13:1 on E85, Indy -1 heads (flow #'s attached), 1.7 Jesels, 4500 Indy intake, 1150 Dominator, TTI step headers, 4800-5000 converter and 3.55s with a 28" tire. This is in a 70 Charger that I'd guess to be 3800-3900# with driver. I realize the converter and gearing may not be optimal, but I like to drive it. I'll be running the Comp 892 lifters in an unbushed stock block. Thanks.
Re: Help with cam choice, 499 with -1s
[Re: Charger453]
#1992638
01/17/16 03:22 PM
01/17/16 03:22 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
