Page 3 of 4 1 2 3 4
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199205
09/25/09 08:44 AM
09/25/09 08:44 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
The backing plate was filled in with a piece of same thickness steel and re-drilled to the correct dia to fit this application.
Driving modern convenience in classic beauty
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199206
09/25/09 08:45 AM
09/25/09 08:45 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is a pic of the nbracket from the Charger and how we cut it so it would work
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199207
09/28/09 04:09 AM
09/28/09 04:09 AM
California
darkrider2 Offline
darkrider2  Offline
California
Looking great Darius, you still planning on going with the B5 blue?
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: darkrider2] #199208
09/28/09 07:42 AM
09/28/09 07:42 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is my "motivation" picture
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199209
09/28/09 07:52 AM
09/28/09 07:52 AM
Slow down your making me look bad.
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: ] #199210
10/01/09 01:22 PM
10/01/09 01:22 PM
California
darkrider2 Offline
darkrider2  Offline
California
sent you a pm Darius
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: darkrider2] #199211
11/28/09 09:31 PM
11/28/09 09:31 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
Car looks great. I have know Bill for years and he is a great guy. I have a Alterkation and I am building a 4 bar rear.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Bakaruda] #199212
11/29/09 12:58 PM
11/29/09 12:58 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Well guys & Gals, I have been slowed on car progress by the economy....suprise, suprise.
i have had to lay off all of my employees but one which means my partner and I are back in the field building kitchens and baths.
There is some progress happening and I may be able to get some pics this week,of the stainless exhaust system. it is looking good with quick disconnects for easy maint. The way the pipes go THROUGH the cross frame rail is VERY cool!
Furstrating that now when The only real big expense left is paint and upholstry I don't have the time to go work on it!
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199213
08/21/10 01:16 AM
08/21/10 01:16 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Finally got some time to work on the car again. I'll post pics in the morning of the 07 Charger dash assembly and console in the 70 GTX.
Re: 70 GTX-5.7 Hemi build-8-21-10 [Re: Darius] #199214
08/21/10 12:37 PM
08/21/10 12:37 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I got the entire dash assembly installed in my GTX.
It was almost as if the engineers for the new LX Charger was thinking "somebody might want to put this in an old B Body" when they designed it, the fitr was that close.
I even got the HVAC box to fit in very nicely, grtting the duct work installed will be a challenge but it is doable.
I realize many of you may not care for this "mod" but it is what I want and I am happy with it so far.
For lots more pics than this site will allow go to
this link.
http://www.forbbodiesonly.com/moparforum/showthread.php?t=1121&page=6
Re: 70 GTX-5.7 Hemi build-8-21-10 [Re: Darius] #199215
08/21/10 12:38 PM
08/21/10 12:38 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Another
Re: 70 GTX-5.7 Hemi build-8-21-10 [Re: Darius] #199216
08/21/10 12:39 PM
08/21/10 12:39 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is the subframe installed with the HVAC box behind it
Re: 70 GTX-5.7 Hemi build-8-21-10 [Re: Darius] #199217
08/21/10 12:50 PM
08/21/10 12:50 PM
It is looking real good Darius, I for one love resto mods so please continue!
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: ] #199218
08/21/10 01:59 PM
08/21/10 01:59 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Did I take enough down time for you to catch up??
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199219
08/21/10 02:13 PM
08/21/10 02:13 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Wow, I'm impressed!
I'm guessing you will have almost ALL the creature comforts of the donor car, not JUST the engine.
I'm a little bit of an "old school" guy usually, but I sure want to see how your car turns out.
CrAzYMoPaRGuY
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199220
08/21/10 03:45 PM
08/21/10 03:45 PM
I am almost a half a roller minus the axles and spool/Locker
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: ] #199221
12/25/11 01:33 PM
12/25/11 01:33 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Suprise!
I finally got some time in. I have a more complete pic post on bbodies only 66-70 forum called "b body stiffening"
Here is a pic of the brake pedal/linkage and you can also see how I fit the steering column using the original column mount bracket
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199222
12/31/11 11:31 AM
12/31/11 11:31 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I got the steering linkage done finally. I figure all told I have appx 30 hours in messing with this part of the swap. A lot of in-and-outs and mock ups to make sure it would be just right before fabbing up the mounts for the Heim joints. This will take a few separate posts.
This first one is the end of the Alterktion frame. I added appx 2" and mounted the lower Heim joint there plus capped off the end so crap won't collect in there.
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199223
12/31/11 11:32 AM
12/31/11 11:32 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here is the bracket I fabbed up
Re: 70 GTX-5.7 Hemi build-9-24-09 [Re: Darius] #199224
12/31/11 11:34 AM
12/31/11 11:34 AM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Here it is installed with the end cap welded on. I just tacked this in , I will finish welding when we take the engine out for paint
Page 3 of 4 1 2 3 4
