Pushrod Recomendation? #199075
01/20/09 04:52 PM
01/20/09 04:52 PM
U.S.
moparniac Offline OP
U.S.
Well I spilled the beans yesterday.... I just couldnt decide between the indy CNC 295's and the CNC 325's
So I got MCH's CNC version which are about 308ish.... so I went for the middle.....
Max Wedge Power
anyway! what pushrods / diameter do you recomend for the heads and spark plugs.... I have a pushrod checker!
compression will be 11.1 to 1
Pump Gas
Harland Sharp rockers
Mopar Performance
Re: Pushrod Recomendation? [Re: moparniac] #199076
01/20/09 05:11 PM
01/20/09 05:11 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I'm running 3/8 Smith Bros chrome moly. They have held up great but weren't cheap.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Pushrod Recomendation? [Re: moparniac] #199077
01/20/09 05:32 PM
01/20/09 05:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Flat tappet or roller, how heavy are the springs
and what ratio rockers
Re: Pushrod Recomendation? [Re: moparniac] #199078
01/20/09 05:43 PM
01/20/09 05:43 PM
an8sec70cuda Offline
Call up Manton and tell em what you have. They'll hook you up w/ what you need. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pushrod Recomendation? [Re: MR_P_BODY] #199079
01/20/09 05:43 PM
01/20/09 05:43 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Manton push rods are very nice, and will save you a substantial amount of money over Smith Bros. I always went with there Stage III push rod, 3/8 thick with a wall thickness of .120. Last few sets I ordered took just about one week to get, and was well under $200 shipped. But this has been a few seasons ago. These push rods, will handle about anything you can throw at them.
As for Spark Plugs
I always had excellent experience with they're Auto lite AR series. Depending on compression the AR 3933 plug should be in the ball park. These plugs are usually In stock at the Local Advance Auto Parts too.
Re: Pushrod Recomendation? [Re: Bob_Coomer] #199080
01/20/09 06:23 PM
01/20/09 06:23 PM
U.S.
U.S.
solid roller .... 1.7 harlands
Mopar Performance
Re: Pushrod Recomendation? [Re: moparniac] #199081
01/21/09 12:22 AM
01/21/09 12:22 AM
U.S.
U.S.
Mopar Performance
Re: Pushrod Recomendation? [Re: moparniac] #199082
01/21/09 02:02 AM
01/21/09 02:02 AM
AndyF Offline
AndyF  Offline
A thick wall 3/8 pushrod or even a 7/16 pushrod is what I'd use with that setup. Good pushrods are expensive so you'll want to measure carefully before ordering. You might want to just order two pushrods at first to doublecheck your measurements and then order the rest if the first two are right on.
Re: Pushrod Recomendation? [Re: moparniac] #199083
01/21/09 02:10 AM
01/21/09 02:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe I can help you w/p-rods as I have 2-sets one ball to ball and one cup to ball. Is this a low deck or 440 block and what rockers are you running? They are smith brothers 3/8`s bad dogs.
