Plug Boot Burn #1990726
01/14/16 04:37 PM
01/14/16 04:37 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I just installed expensive(to me at least) ceramic coated headers on my '69 Super Bee with 383. The #6 plug wire boot is super close to the header tube, burns in a small amount of time and shorts out. I've used an insulated sleeve and it eventually allows the boot to burn away too. I don't want to bend and beat on the headers and mess up the coating. I'm using MSD high heat wires/boots. Any suggestions...?
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Plug Boot Burn [Re: Texas383] #1990732
01/14/16 04:53 PM
01/14/16 04:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
a good quality sleeve will help out with this. i have the same problem and most of us do. really the only way 100% is to route the wires factory style instead of 'up and over'. using a bendable plug connector will help to. the other option is to invest in the very spendy performance wires and boots from Firecore or various other manufacturers.
Re: Plug Boot Burn [Re: Texas383] #1990738
01/14/16 05:07 PM
01/14/16 05:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Could you swap to a 90 degree end?
Doug
Re: Plug Boot Burn [Re: Texas383] #1990836
01/14/16 07:50 PM
01/14/16 07:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A picture of the issue might help solve it.
Don't be the exception.
Re: Plug Boot Burn [Re: Texas383] #1990850
01/14/16 08:21 PM
01/14/16 08:21 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Been running 'Mag-na-Cor' wires(with 'adjustable' boots)cozied-up to Hooker headers for many years...
No 'sleeves'...
No issues...
Re: Plug Boot Burn [Re: RSNOMO] #1990881
01/14/16 09:07 PM
01/14/16 09:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
No 'sleeves'...
No issues...
way pricey for most of us whiney
Re: Plug Boot Burn [Re: mikemee1331] #1990938
01/14/16 10:27 PM
01/14/16 10:27 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Have no idea what they list for now...
Back when I bought 'em, they weren't bad at all...
(Of course, back then, a whole bunch fer these cars weren't bad...
Unlike today...
When you durn near got to win the lotto to re-do yer Hemi RR...)
Re: Plug Boot Burn [Re: RSNOMO] #1991013
01/15/16 12:23 AM
01/15/16 12:23 AM
IN
ahy Offline
ahy  Offline
IN
On my "B" engine with 1 7/8 TTI headers I started with a set of Taylor wires. They fit great on the engine stand with headers installed but not so much in the car. With obstacles like power steering I had to switch them around and they burnt pretty fast.
A set of MSD "adjustable boot" wires worked much better. Basically you bend the boot as needed for each hole. No burnt wires after that including a long road trip and road track time.
Re: Plug Boot Burn [Re: Texas383] #1991036
01/15/16 01:10 AM
01/15/16 01:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What brand headers are they ? I know with the Firecore wires I use they have never even started to look burnt and some of mine are a little close. Ron
Re: Plug Boot Burn [Re: 383man] #1991062
01/15/16 02:10 AM
01/15/16 02:10 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've ran Taylor's through extensive abuse both racing and street driving. Never...ever burned them...Is it possible its bad lean...maybe early or late on timing and generating excessive heat? shruggy
...FAFO...
Re: Plug Boot Burn [Re: Texas383] #1991225
01/15/16 12:42 PM
01/15/16 12:42 PM
moparx Online content
moparx  Online Content
at one time, wasn't there an out fit that offered ceramic plug ends that you could install on your wires to cure the problem described ? if i remember correctly, they were white in color, and came in straight and 90* versions.
beer
Re: Plug Boot Burn [Re: Texas383] #1991245
01/15/16 01:55 PM
01/15/16 01:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with skicker.Taylors on my 440 with 2 inch TTIs never burnt.Mine were on at least 15 years and still looked good.My kid ran them on the 413 with 2 1/8 headers.His were on 4 years at least.He did run covers on 8.Just replaced my taylors as the old ones looked tacky.The Spiro pros are some of the best Ive ever run.Oh yeah run them on all the SBs also with headers.Ran them on my 57 chrysler also.Rocky
Chrysler Firepower
Re: Plug Boot Burn [Re: moparx] #1991297
01/15/16 03:29 PM
01/15/16 03:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
beer
Jacobs?
Re: Plug Boot Burn [Re: Texas383] #1991402
01/15/16 06:18 PM
01/15/16 06:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Raja used to make ends.They would last forever.I had a set.Trouble was where they went on the plug was open.Get rain etc and misfire.Rocky
Chrysler Firepower
Re: Plug Boot Burn [Re: mikemee1331] #1991877
01/16/16 12:44 PM
01/16/16 12:44 PM
jersey
Spaceman Spiff Offline
jersey
beer
Jacobs?
Yup. Jacobs electronics. I had a set on a '70 chevelle. Loved them. The boot could lay right on the header tube, with no problem. The boots were a little bulky, so you had to run a shorty plug.
I had their complete pro street ignition system.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Plug Boot Burn [Re: Texas383] #1991879
01/16/16 12:49 PM
01/16/16 12:49 PM
jersey
jersey
Re: Plug Boot Burn [Re: Texas383] #1992506
01/17/16 01:02 PM
01/17/16 01:02 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I'm not sure a 90 degree boot will help with the plug being next to the header tube.
I didn't think about using a shorty plug. Whats a good plug part # for that?
Here's my combo:
383 bored .060
Keith Black 10:1
Mopar 509
Edelbrock Torker
ThermoQuad 910cfm
Mopar Chrome Box
37 degrees total
1969 Y2 Super Bee
Re: Plug Boot Burn [Re: Texas383] #1993155
01/18/16 04:36 AM
01/18/16 04:36 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
I think I've got a autolite 23 on #6
Re: Plug Boot Burn [Re: Texas383] #1993218
01/18/16 11:40 AM
01/18/16 11:40 AM
someone at one time recommended a lawnmower plug that was a good heat range for this type of application. any one remember the plug number ?
beer
Re: Plug Boot Burn [Re: moparx] #1993222
01/18/16 11:47 AM
01/18/16 11:47 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Weren't the Champion J plugs the shorty's? Maybe a J8 or something depending on how hot you want... shruggy
...FAFO...
