Engine cradle/stand. #1989665
01/13/16 01:19 AM
01/13/16 01:19 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What kind of engine cradle you guys using to haul your engine to the Dyno? Looking for something inexpensive. Will only get used once.
Re: Engine cradle/stand. [Re: mopar dave] #1989690
01/13/16 01:59 AM
01/13/16 01:59 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used some pieces of 2 x 10 lumber, 2 pieces along the pan rail and longer pieces front and back to keep the engine from tipping over . The front was cut out for the balancer fit.
Re: Engine cradle/stand. [Re: mopar dave] #1989692
01/13/16 02:04 AM
01/13/16 02:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I welded up some 1" square tubing.. then bolted
the engine on it.. then strapped it on my small
open trailer... I ended up using it to ship my
engine off to Australia in a wooden crate I made up
wave
Re: Engine cradle/stand. [Re: rowin4] #1989753
01/13/16 06:09 AM
01/13/16 06:09 AM
iagree I used 2x8 and cut out a small notch on the front to clear the oil pump and oil filter. I did place the front and rear longer pieces directly under the front and rear oil pan bolts so it didn't put any strain on the crankshaft in the front or rear by supporting the crank. thumbs I have made several different ones over the years to transport different motors to the dyno, the ones with the external oiling systems need some notching on the drivers side support rail also to clear those fittings and lines scope. Summit sells a metal engine dolly that a local guy used as a model to make one for BB and another one for SB Mopars, that works well also work
Re: Engine cradle/stand. [Re: mopar dave] #1989777
01/13/16 11:29 AM
01/13/16 11:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave you and I seem to be progressing at about the same rate on our builds biggrin . I started building a cradle last night to put my engine on to transport it to the dyno in February. I have one I built several years ago but it has my 340 on it, plus it has casters on it.
Like Mike I use 1" tube, this one will have tabs to bolt to the engine, the first one I just bolted through the tube. Also on this one I will bolt the casters on, if I need to transport another engine I can just take the casters off. Also I'm going to make a couple tabs to bolt on the heads for ratchet straps.
Re: Engine cradle/stand. [Re: mopar dave] #1989780
01/13/16 11:39 AM
01/13/16 11:39 AM
Mt Morris Michigan
Mt Morris Michigan
thanks guys. im looking to buy something quick. i have seem some with 1" square tubing for under $20 for chevy, but i dont see any for mopar. i seen the ones summit sells, but their 60-70 bucks. ill keep checking ebay. something will come up.
Re: Engine cradle/stand. [Re: mopar dave] #1989830
01/13/16 12:57 PM
01/13/16 12:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have used a truck tire or two when taking the engine across town to the dyno. All it needs is strapped up straight so it doesn't roll over.
Master, again and still
Re: Engine cradle/stand. [Re: DaveRS23] #1989836
01/13/16 01:14 PM
01/13/16 01:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made mine so it was a ready to go engine.. headers
and everything were on it.. they picked it up, stand
and all with a fork lift with the forks together
and from there the over head crane set it in place
on the dyno... I had tabs welded on it so it bolted
to 2 bell housing points and the motor mount ears..
I used it twice for the dyno.. had a issue the first
time so I had it pulled and went back later... it
worked great... plus I had a spare block on it in the
corner for a while.. then as I said.. it went down
under when I sold my engine
wave
Re: Engine cradle/stand. [Re: MR_P_BODY] #1989860
01/13/16 01:49 PM
01/13/16 01:49 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I had the Summit one for the small block it was a good piece , a few years ago I sold a 318 I had and the buyer wanted the cradle too so I sold it to him. I now use a small block Chevy one a friend gave me after he Won it in a drawing, I converted it to use with my small block Mopars.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Engine cradle/stand. [Re: mopar dave] #1989866
01/13/16 01:57 PM
01/13/16 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mancini, Jegs, Summit all sell Mopar engine cradles. With a Motorplate druysump etc we always find it easy enough to build one from 1" square tubing to get what we need.
Re: Engine cradle/stand. [Re: mopar dave] #1989896
01/13/16 02:49 PM
01/13/16 02:49 PM
Mt Morris Michigan
Mt Morris Michigan
i dont have the time to build anything right now. i found one on ebay for about $35. think ill just get it even thou it doesnt look too sturdy. i just dont want the engine flopping around in the back of my truck. i would like to put the headers on as well that way we can just roll it into the dyno cell when i get there.
Re: Engine cradle/stand. [Re: mopar dave] #1989900
01/13/16 02:53 PM
01/13/16 02:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have a mig welder... you could be done by
the time you get one from e-bay.. takes all of a
1/2 hour to burn one together thats nice and sturdy
EDIT
Or just buy the tubing and come by my place and I'll
burn one together for you.. free.. just need the tubing
I have a few blocks here to mock it up
wave
Re: Engine cradle/stand. [Re: mopar dave] #1989906
01/13/16 03:04 PM
01/13/16 03:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Agree with MrP, quick and easy to do for sure and cannot neat that offer. Bet he even has some 1" tubing smile
Re: Engine cradle/stand. [Re: mopar dave] #1989908
01/13/16 03:05 PM
01/13/16 03:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: Engine cradle/stand. [Re: Al_Alguire] #1989973
01/13/16 04:23 PM
01/13/16 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nope.. no 1" tubing.. I did have a couple of feet of 1 1/4
but not enough
wave
Re: Engine cradle/stand. [Re: MR_P_BODY] #1990307
01/13/16 11:52 PM
01/13/16 11:52 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks again for the offer Mike. If you were next door I would be all over that. I do appreciate that. I need something in the next 2-3 weeks. Should be ready by then. My problem is time. There's never enough of it.
Re: Engine cradle/stand. [Re: mopar dave] #1990315
01/14/16 12:04 AM
01/14/16 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No problem
wave
Re: Engine cradle/stand. [Re: mopar dave] #1990366
01/14/16 01:36 AM
01/14/16 01:36 AM
AndyF Online content
AndyF  Online Content
I make my own dollies so I can put a large diameter caster on them. They roll a lot easier when they have a big caster wheel. I also include some holes for the tie downs to hook into.
Re: Engine cradle/stand. [Re: AndyF] #1990370
01/14/16 01:42 AM
01/14/16 01:42 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Andy does Mancini sell those? I am in need! Can you supply the part number?
Re: Engine cradle/stand. [Re: AndyF] #1990420
01/14/16 03:03 AM
01/14/16 03:03 AM
Texas
mprhound Offline
mprhound  Offline
Texas
Those would be great if you could still buy them
I tried Mancini a couple of months ago and they said they Could not get them anymore
Wished I had one
