Correct Size Nut for E Body Dashpad Studs #198893
01/20/09 12:18 PM
01/20/09 12:18 PM
Anonymous OP
Anonymous OP
Can someone tell me the correct size and thread pitch of the studs that attach the pad to the metal dash frame on an E body dashpad? Thanks!!
Re: Correct Size Nut for E Body Dashpad Studs #198894
01/20/09 07:01 PM
01/20/09 07:01 PM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
I guess the first thing that comes to my mind is why, are you missing the orig. stamped steel nuts? I believe they are a #10 x 24 tpi. that's what mine look like. Though I'm sure I'll be corrected if wrong.
Todd
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: Correct Size Nut for E Body Dashpad Studs #198895
01/20/09 07:15 PM
01/20/09 07:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Don't hold me to it but I think they are 10-24 open ended pal nut
Re: Correct Size Nut for E Body Dashpad Studs #198896
01/20/09 10:49 PM
01/20/09 10:49 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The factory nuts as already mentioned are stamped steel. The thread is indeed 10-24. I know of no reason not to use regular zinc or stainless steel nuts with a washer.
Craig
Re: Correct Size Nut for E Body Dashpad Studs [Re: denfireguy] #198897
01/21/09 06:41 PM
01/21/09 06:41 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Did you try yet to find them new from Tom @ R/T Specialties? He may have them. Let us know either way. I have original extras if you really need them. Nick
Re: Correct Size Nut for E Body Dashpad Studs [Re: ebodyseast] #198898
01/21/09 08:51 PM
01/21/09 08:51 PM
Anonymous OP
Anonymous OP
these
