Can someone tell me the correct size and thread pitch of the studs that attach the pad to the metal dash frame on an E body dashpad? Thanks!!
The factory nuts as already mentioned are stamped steel. The thread is indeed 10-24. I know of no reason not to use regular zinc or stainless steel nuts with a washer. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
