thick valve cover gaskets for sb? #1988425
01/11/16 02:14 PM
01/11/16 02:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
iv asked this before awhile back and came up with nothing. does anyone make a 1/4" thick vc gasket for small blocks yet? been stacking two felpro vc gaskets and thou it works for cleance it just plain looks like crap.
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1988481
01/11/16 03:12 PM
01/11/16 03:12 PM
Renton Washington
Triple Threat Offline
Renton Washington
I ran the Edelbrock gaskets with great success, I believe they're shy of 1/4 but they are thicker than the Felpros and such I've used in the past.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: thick valve cover gaskets for sb? [Re: Triple Threat] #1988499
01/11/16 03:29 PM
01/11/16 03:29 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks. ill look them up
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1988514
01/11/16 03:41 PM
01/11/16 03:41 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
several years ago I inquired about some aluminum spacer's to put under mine so it wouldn't let the oil drain out of the head while doing valve adjustment's after a run and there was a member that made them, topside340 I believe his name was/is,,bought a set and used a thin rubberized cork gasket under them against the head and used a good rubber gasket under the VC, fixed my problem and didn't distract the looks.
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1988524
01/11/16 03:49 PM
01/11/16 03:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Fel Pro makes one that is close to 1/4", I have some in the shop that I can measure and get the p/n if you want.
Re: thick valve cover gaskets for sb? [Re: justinp61] #1988527
01/11/16 03:54 PM
01/11/16 03:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Speak with GREG at SUPERPERFORMANCE gaskets up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: thick valve cover gaskets for sb? [Re: justinp61] #1988556
01/11/16 04:16 PM
01/11/16 04:16 PM
Mt Morris Michigan
Mt Morris Michigan
sure get me the number when ya get a chance. i talked to greg about these awhile back and they are under 1/4" as well.
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1988604
01/11/16 04:53 PM
01/11/16 04:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave I measured the Fel Pros I have, .200. They are pretty hard so I don't think they'll compress much. VS 50184R
Re: thick valve cover gaskets for sb? [Re: justinp61] #1988614
01/11/16 05:05 PM
01/11/16 05:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How thick are the MP ones.. the silicone over the
steel frame... they have to be better than 3/16"..
I'll measure one today
wave
Re: thick valve cover gaskets for sb? [Re: justinp61] #1988687
01/11/16 07:05 PM
01/11/16 07:05 PM
Mt Morris Michigan
Mt Morris Michigan
Here's one I found. 1646 felpro .313 thick. Ever seen these?
Re: thick valve cover gaskets for sb? [Re: justinp61] #1989034
01/12/16 02:12 AM
01/12/16 02:12 AM
Mt Morris Michigan
Mt Morris Michigan
I think those are the same as the edelbrock for thickness.
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1989045
01/12/16 02:27 AM
01/12/16 02:27 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I believe those are the ones I've been using for a while. They're close to 5/16 and have have a steel core. They work great w/ a vacuum pump.
Re: thick valve cover gaskets for sb? [Re: dartman366] #1989049
01/12/16 02:39 AM
01/12/16 02:39 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Excellent product, excellent service. I bought two sets in 2015.
http://www.medicemfg.com/products_get.php?c=Valve%20Cover%20Spacers%20-%20Mopar
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1989056
01/12/16 02:55 AM
01/12/16 02:55 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar 89-91 318-360 truck vc gaskets IIRC.
Mopar to the bone!!!
Re: thick valve cover gaskets for sb? [Re: DavidDean] #1989064
01/12/16 03:31 AM
01/12/16 03:31 AM
Mt Morris Michigan
Mt Morris Michigan
yes, 5/16 thick. just ordered a pair.
Re: thick valve cover gaskets for sb? [Re: mopar dave] #1989102
01/12/16 09:32 AM
01/12/16 09:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I found a Fel-pro on summit that is pretty much two cork gaskets stacked on a thin metal frame(thin!) They are fairly rigid but compress well, I have been very happy with them.
68 Barracuda Formula S 340
Re: thick valve cover gaskets for sb? [Re: Bad340fish] #1989160
01/12/16 12:30 PM
01/12/16 12:30 PM
Mt Morris Michigan
Mt Morris Michigan
i believe those are what i ordered. p#1646
