Re: thick valve cover gaskets for sb?
[Re: mopar dave]
#1988481
01/11/16 03:12 PM
01/11/16 03:12 PM
Triple Threat
Renton Washington
I ran the Edelbrock gaskets with great success, I believe they're shy of 1/4 but they are thicker than the Felpros and such I've used in the past.
[Re: mopar dave]
#1988514
01/11/16 03:41 PM
01/11/16 03:41 PM
dartman366
Mt. Vernon, Ohio
several years ago I inquired about some aluminum spacer's to put under mine so it wouldn't let the oil drain out of the head while doing valve adjustment's after a run and there was a member that made them, topside340 I believe his name was/is,,bought a set and used a thin rubberized cork gasket under them against the head and used a good rubber gasket under the VC, fixed my problem and didn't distract the looks.
[Re: justinp61]
#1988614
01/11/16 05:05 PM
01/11/16 05:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How thick are the MP ones.. the silicone over the steel frame... they have to be better than 3/16".. I'll measure one today
[Re: dartman366]
#1989049
01/12/16 02:39 AM
01/12/16 02:39 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
several years ago I inquired about some aluminum spacer's to put under mine so it wouldn't let the oil drain out of the head while doing valve adjustment's after a run and there was a member that made them, topside340 I believe his name was/is,,bought a set and used a thin rubberized cork gasket under them against the head and used a good rubber gasket under the VC, fixed my problem and didn't distract the looks. Excellent product, excellent service. I bought two sets in 2015. http://www.medicemfg.com/products_get.php?c=Valve%20Cover%20Spacers%20-%20Mopar
[Re: mopar dave]
#1989056
01/12/16 02:55 AM
01/12/16 02:55 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Mopar 89-91 318-360 truck vc gaskets IIRC.
Mopar to the bone!!!
[Re: mopar dave]
#1989102
01/12/16 09:32 AM
01/12/16 09:32 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I found a Fel-pro on summit that is pretty much two cork gaskets stacked on a thin metal frame(thin!) They are fairly rigid but compress well, I have been very happy with them.
68 Barracuda Formula S 340
