Need help with Pertronix Ignitor install
#1987859
01/10/16 08:05 PM
01/10/16 08:05 PM
Posts: 364 US
f2502011
US
I'm trying to install an Ignitor kit in my Prestolite distributor for 1970 Challenger. I've taken the points and condenser out and tried to install this kit but I can't seem to get it installed. First the holes in the ignitor plate weren't machined exactly right to line up with the holes in the breaker plate. It said to install the ignitor plate where the middle of the 3 holes on one side will go where the condenser was screwed to the plate and the other hole would line up with where the points screw was and the ground strap attached. The holes were off just enough to prevent that from working as is so I widened the hole for the ground strap enough to let it fasten to the plate and not disturb where the ignitor plate needed to be with the two outer holes allowing it to line up with the small posts for the condenser locator. After that, I can't get the ring go down far enough on the cam to let the rotor go all the way down so the cap won't go on. Is there a secret to this?
It also says to wire the red wire to the ignition or 12V side of the ballast resistor. The resistor on mine has a blue wire to one post and a blue and brown wire to the other. Assembly manual lists them as ignition 1 and ignition 2. Should I get this to install which post does it go to?
1970 EK2 T/A 727
Re: Need help with Pertronix Ignitor install
[Re: f2502011]
#1987870
01/10/16 08:12 PM
01/10/16 08:12 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Hopefully someone can help you with this. I can only say that I bought the IgnitorIII billet distributor, it took some time grinding my Edelbrock head so the distributor would clear it but after that it has ran awesome for 2 years now and it only took 2 wires to hook it up, straight to the coil, then one more wire just from a 12v ignition. Has a rev limiter too.
[Re: f2502011]
#1987904
01/10/16 09:15 PM
01/10/16 09:15 PM
Posts: 364 US
f2502011
US
I got the ring on. Had a small ridge in the plastic underside that was catching. Now if I could just figure out where to hook the red wire to the ballast resistor I may have a running car. I say may have because I'm not real confident in Pertronix manufacturing abilities at this point.
1970 EK2 T/A 727
[Re: red 69 runner]
#1988014
01/10/16 11:13 PM
01/10/16 11:13 PM
Posts: 364 US
f2502011
US
If you would have got the ignitor 11 and matching coil you can by pass the ballast and just hook red wire to + side of coil and the other wire to the - side of the coil. I can do that anyway. I need to know how to wire the setup while including the ballast resistor so everything looks correct too. The ballast has a single blue wire on the passenger side or upside and a blue and brown wire on the lower post or toward the drivers side. The assembly manual says the single blue wire is ignition 1 the brown and blue wire is ignition 2. The Pertronix directions say to wire it to the ignition switch side of the resistor. Which post is it? I've attached the instructions.
1970 EK2 T/A 727
[Re: f2502011]
#1988056
01/10/16 11:50 PM
01/10/16 11:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The switch side of the resistor has battery voltage (or close to it) on it in RUN. The coil side of the resistor will have several volts less, in RUN. Put a meter on it.
If all you have is a test light then disconnect one side and the side that lights up in RUN is the one you want.
[Re: f2502011]
#1988071
01/11/16 12:03 AM
01/11/16 12:03 AM
RapidRobert
EDIT! keeping stock coil & stock ballast resistor. With them wired up as OE. P black wire to coil neg primary terminal. P red wire to ballast blue wire (ign1 run) end of ballast resistor. Do NOT connect (T) the P red wire to the coil positive primary terminal as in the P illustration. Done!
[Re: f2502011]
#1988209
01/11/16 02:42 AM
01/11/16 02:42 AM
Posts: 18,157 Mass
DAYCLONA
Mass
If you would have got the ignitor 11 and matching coil you can by pass the ballast and just hook red wire to + side of coil and the other wire to the - side of the coil. I can do that anyway. I need to know how to wire the setup while including the ballast resistor so everything looks correct too. The ballast has a single blue wire on the passenger side or upside and a blue and brown wire on the lower post or toward the drivers side. The assembly manual says the single blue wire is ignition 1 the brown and blue wire is ignition 2. The Pertronix directions say to wire it to the ignition switch side of the resistor. Which post is it? I've attached the instructions. FYI...be sure to re-time the ignition as the Pertronix install can rephase the system anywhere from 5 degrees ATDC to 15 degrees BTDC, so depending on where your current timing is, your engine might not start because the timing is too far off Get rid of the ballast, it's a weak link in the system, the red wire from the HallCell goes to the positive side of the coil, the black lead from the HallCell goes to the negative side of the coil, the blue/dark blue ignition lead from your bulkhead connector goes to the positive side of the coil, gut out the ballast resistor and solder in an insulated 10 gauge piece of wire in the back cavity of the resistor, now just attach the resistor leads as they were originally on the ballast, you now have the look of having the ballast, but without the issues of a ballast, plus the system is now running a true 12 volts, be sure to gap the HallCell with the plastic gauge supplied, don't use any metal feeler gauges, copper terminal cap only, no solid core wires, don't remove the green tape on the HallCell magnet, don't leave the key in the run position for more than 30 seconds without the engine running, if you need to do so, disconnect the RED lead from the positive side of the coil...you are using the correct Pertronix coil?...right Mike
[Re: RapidRobert]
#1989085
01/12/16 07:14 AM
01/12/16 07:14 AM
Posts: 364 US
f2502011
US
EDIT! keeping stock coil & stock ballast resistor. With them wired up as OE. P black wire to coil neg primary terminal. P red wire to ballast blue wire (ign1 run) end of ballast resistor. Do NOT connect (T) the P red wire to the coil positive primary terminal as in the P illustration. Done! That's what I was looking for. Pertronix red wire to single blue wire side of ballast resistor.
1970 EK2 T/A 727
[Re: DAYCLONA]
#1989086
01/12/16 07:23 AM
01/12/16 07:23 AM
Posts: 364 US
f2502011
US
If you would have got the ignitor 11 and matching coil you can by pass the ballast and just hook red wire to + side of coil and the other wire to the - side of the coil. I can do that anyway. I need to know how to wire the setup while including the ballast resistor so everything looks correct too. The ballast has a single blue wire on the passenger side or upside and a blue and brown wire on the lower post or toward the drivers side. The assembly manual says the single blue wire is ignition 1 the brown and blue wire is ignition 2. The Pertronix directions say to wire it to the ignition switch side of the resistor. Which post is it? I've attached the instructions. FYI...be sure to re-time the ignition as the Pertronix install can rephase the system anywhere from 5 degrees ATDC to 15 degrees BTDC, so depending on where your current timing is, your engine might not start because the timing is too far off Get rid of the ballast, it's a weak link in the system, the red wire from the HallCell goes to the positive side of the coil, the black lead from the HallCell goes to the negative side of the coil, the blue/dark blue ignition lead from your bulkhead connector goes to the positive side of the coil, gut out the ballast resistor and solder in an insulated 10 gauge piece of wire in the back cavity of the resistor, now just attach the resistor leads as they were originally on the ballast, you now have the look of having the ballast, but without the issues of a ballast, plus the system is now running a true 12 volts, be sure to gap the HallCell with the plastic gauge supplied, don't use any metal feeler gauges, copper terminal cap only, no solid core wires, don't remove the green tape on the HallCell magnet, don't leave the key in the run position for more than 30 seconds without the engine running, if you need to do so, disconnect the RED lead from the positive side of the coil...you are using the correct Pertronix coil?...right Mike Ignitor for my application didn't come with a plastic gauge to gap and no green tape. I'm simply wanting to eliminate points. I want to keep the ballast, original coil, wires etc.. Timing with points was at 16 btdc.
1970 EK2 T/A 727
[Re: f2502011]
#1989090
01/12/16 07:49 AM
01/12/16 07:49 AM
Posts: 364 US
f2502011
US
I have either NOS but likely reproduction 1970 plug wires that say electronic suppression on them and have correct date codes. Are these ok and not solid core? Not sure how to tell.
1970 EK2 T/A 727
[Re: f2502011]
#1989243
01/12/16 02:42 PM
01/12/16 02:42 PM
RapidRobert
Are these ok and not solid core? they're OK, they are suppression
[Re: f2502011]
#1993209
01/18/16 11:20 AM
01/18/16 11:20 AM
Posts: 364 US
f2502011
US
This 1384 ignitor kit didn't come with anything to set the gap between the module and the magnet and it looks like it's not supposed to. So, is there a way to make sure it's in the right place?
The module has a hole in the center of 2 other holes that allows for a screw in the same place as the one for the condenser. It has two other holes, one on each side of the one for the screw, that fit over a couple of small posts that were locators for the condenser I assume. I haven't tried to start it yet, but it looks to me like a fairly large gap between the module and the magnet so I want to be sure if it doesn't crank whether it's the position of the module or the timing being way off.
1970 EK2 T/A 727
[Re: f2502011]
#1993249
01/18/16 12:44 PM
01/18/16 12:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The module has a hole in the center of 2 other holes that allows for a screw in the same place as the one for the condenser. It has two other holes, one on each side of the one for the screw, that fit over a couple of small posts that were locators for the condenser I assume. I haven't tried to start it yet, but it looks to me like a fairly large gap between the module and the magnet so I want to be sure if it doesn't crank whether it's the position of the module or the timing being way off. The Ignitor I and II HallCell modules/magnets have an adjustable air gap, only the Ignitor III adjusts the Dwell (gap) electronically, the gap is .030, find anything other than metal (plastic, paper,etc,etc)that is non conductive or magnetic to gap the Dwell angle
[Re: DAYCLONA]
#1993299
01/18/16 02:18 PM
01/18/16 02:18 PM
Posts: 364 US
f2502011
US
This kit doesn't really have any adjustment potential that I see unless I start machining things. It has two small round holes that just fit over the small posts used to help locate the condenser and a round hole for the screw. The holes aren't slotted to allow for movement. I've seen the 0.03 gap listed in multiple places for different kits, but for this one it's like it is made to only go in as is. Maybe that's why it didn't come with the plastic gaping tool included with other kits?
1970 EK2 T/A 727
[Re: f2502011]
#1993319
01/18/16 02:37 PM
01/18/16 02:37 PM
RapidRobert
you might see what the gap is (right now) with something non metallic & mike it
[Re: f2502011]
#1993347
01/18/16 03:08 PM
01/18/16 03:08 PM
Posts: 364 US
f2502011
US
Here's a photo of the installed unit. Best I can tell the gap is closer to 0.100.
1970 EK2 T/A 727
[Re: f2502011]
#1993354
01/18/16 03:15 PM
01/18/16 03:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
This kit doesn't really have any adjustment potential that I see unless I start machining things. It has two small round holes that just fit over the small posts used to help locate the condenser and a round hole for the screw. The holes aren't slotted to allow for movement. I've seen the 0.03 gap listed in multiple places for different kits, but for this one it's like it is made to only go in as is. Maybe that's why it didn't come with the plastic gaping tool included with other kits? Is this kit for the Prestolite dual point dist?, if it is, then there is no adjustment feature for the HallCell, I just hope you indexed the magnet pick up ring properly before seating it fully on the dist lobe (usually an issue with this kit), the only play there should be with the magnet pick up ring is what end play the actual shaft of the dist has, if the magnet can rock/shift about on the base dist lobe, then it's either damaged or not installed properly, otherwise your good to go, be sure to check/re-time the ignition Mike
[Re: DAYCLONA]
#1993423
01/18/16 05:06 PM
01/18/16 05:06 PM
Posts: 364 US
f2502011
US
Mike
How do I know if it's indexed properly? It's seated all the way and has no play other than the up down that's in the shaft itself.
1970 EK2 T/A 727
[Re: f2502011]
#1993442
01/18/16 05:35 PM
01/18/16 05:35 PM
Posts: 364 US
f2502011
US
I've got another ballast resistor I plan to gut if everything works. Could I try it by temporarily wiring the two ends that attach to the ballast and then hooking the red wire to the + on the coil?
1970 EK2 T/A 727
