W-2 race head rockers. #1987423
01/10/16 09:34 AM
01/10/16 09:34 AM
Muncie
Racebuddy Offline OP
Muncie
Wondering what rockers are available for a W-2 race head? Updating from my old Norris rockers. Need an offset rocker that oils thru the shaft, not the pushrod. What kind and where can I get them??
Re: W-2 race head rockers. [Re: Racebuddy] #1987424
01/10/16 09:47 AM
01/10/16 09:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
T&D.. you need the stands.. I forget if those
are the offset stands and shafts or on center
line... both sets of W-2s I have are the econo
type.. 1 set of regular and 1 set of long valves
wave
Re: W-2 race head rockers. [Re: MR_P_BODY] #1987537
01/10/16 01:50 PM
01/10/16 01:50 PM
oregon
greendart408 Offline
oregon
Harland sharp is what I ran for yrs on mine, with zero issues.
Re: W-2 race head rockers. [Re: greendart408] #1987742
01/10/16 05:59 PM
01/10/16 05:59 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Jesel also makes them but a LOT of work needed to use them.
Bill
Re: W-2 race head rockers. [Re: Racebuddy] #1987799
01/10/16 06:59 PM
01/10/16 06:59 PM
I used the Mopar, Crane brand extruded aluminum roller tip rockers on the 418 C.I. race W2 headed pump gas stroker motor I built for 9secondPhil years ago. He put a lot of laps and street miles on it with no problems that I'm aware of shruggy Buy the best ones you can afford up
Re: W-2 race head rockers. [Re: Racebuddy] #1987820
01/10/16 07:20 PM
01/10/16 07:20 PM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
I used Harlan Sharp for years with zero issues. Engine was 418 SB with Arrington/Diamond heads, 726HP and 665 TQ, left at 5800 RPM's and car weighed 3550 with me in it. I was far from easy on them.
Re: W-2 race head rockers. [Re: Cab_Burge] #1987821
01/10/16 07:20 PM
01/10/16 07:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Which stands did you use
wave
Re: W-2 race head rockers. [Re: HR5058] #1987829
01/10/16 07:31 PM
01/10/16 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was that the W-5 heads... what did the car run
wave
Re: W-2 race head rockers. [Re: MR_P_BODY] #1987862
01/10/16 08:07 PM
01/10/16 08:07 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have ran the race W2 heads for years,my last combo with well over 900 runs and had the non - roller ductile iron rockers and never broke one and only had to replace one adjuster last year. They are kind of similar to the 273 adjustable rockers.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: W-2 race head rockers. [Re: MR_P_BODY] #1987917
01/10/16 09:36 PM
01/10/16 09:36 PM
Muncie
Muncie
My Norris rockers oiled thru the shaft. I want my new rockers to oil thru the shaft also and not the pushrod. Do the Harland Sharps oil thru shaft?? I believe the T and D does??
Re: W-2 race head rockers. [Re: Racebuddy] #1987927
01/10/16 09:43 PM
01/10/16 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
T&D has both styles.. shaft and PR oiling.. I'm
running PR oiling on my shaft type.. I closed off
the hole in the head on my econo W-2s
wave
Re: W-2 race head rockers. [Re: Racebuddy] #1987956
01/10/16 10:12 PM
01/10/16 10:12 PM
oregon
oregon
Yes, they oil through the shaft.
Re: W-2 race head rockers. [Re: MR_P_BODY] #1987982
01/10/16 10:39 PM
01/10/16 10:39 PM
Muncie
Muncie
I just got in a new set from Indy Cylinder Head and i didnt have them made for oiling. so its good to know i can get either rocker. Time to go shopping
Re: W-2 race head rockers. [Re: Racebuddy] #1987997
01/10/16 11:00 PM
01/10/16 11:00 PM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
They were the old set of Nascar/NHRA set from long ago. These actually were on Buddy Arrington's Talladega car. Duster ran low 9.90's with Glide and 4.56 gears in a Dana.
