W-2 race head rockers.
#1987423
01/10/16 09:34 AM
01/10/16 09:34 AM
Posts: 611 Muncie
Racebuddy
Muncie
Wondering what rockers are available for a W-2 race head? Updating from my old Norris rockers. Need an offset rocker that oils thru the shaft, not the pushrod. What kind and where can I get them??
Re: W-2 race head rockers.
[Re: Racebuddy]
#1987424
01/10/16 09:47 AM
01/10/16 09:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
T&D.. you need the stands.. I forget if those are the offset stands and shafts or on center line... both sets of W-2s I have are the econo type.. 1 set of regular and 1 set of long valves
[Re: Racebuddy]
#1987799
01/10/16 06:59 PM
01/10/16 06:59 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I used the Mopar, Crane brand extruded aluminum roller tip rockers on the 418 C.I. race W2 headed pump gas stroker motor I built for 9secondPhil years ago. He put a lot of laps and street miles on it with no problems that I'm aware of Buy the best ones you can afford
[Re: MR_P_BODY]
#1987862
01/10/16 08:07 PM
01/10/16 08:07 PM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
I have ran the race W2 heads for years,my last combo with well over 900 runs and had the non - roller ductile iron rockers and never broke one and only had to replace one adjuster last year. They are kind of similar to the 273 adjustable rockers.
[Re: Racebuddy]
#1987927
01/10/16 09:43 PM
01/10/16 09:43 PM
MR_P_BODY
My Norris rockers oiled thru the shaft. I want my new rockers to oil thru the shaft also and not the pushrod. Do the Harland Sharps oil thru shaft?? I believe the T and D does??
T&D has both styles.. shaft and PR oiling.. I'm running PR oiling on my shaft type.. I closed off the hole in the head on my econo W-2s
[Re: Racebuddy]
#1987956
01/10/16 10:12 PM
01/10/16 10:12 PM
Posts: 1,073 oregon
greendart408
oregon
Yes, they oil through the shaft.
