68 Charger brake booster
#198761
01/20/09 07:28 AM
01/20/09 07:28 AM
Posts: 450 DFW
68RRFlyer
DFW
Hi Guys, I have a question in regards to a 68 Charger's power brake booster. Does the factory booster have the retaining strap that runs around the booster to sandwich the two booster halves together held in place by a long bolt that is subsequently bent to match the contour of the booster? You can see it on the booster in this pic at about the 9 o'clock position. Seems odd that the factory would bend a bolt like that, but maybe so. It still has some factory parking on it too. I took it apart to inspect/restore it and was just curious if I was wasting my time if it was a replacement. Thanks! Cheers
