68 Charger brake booster #198761
01/20/09 07:28 AM
01/20/09 07:28 AM
DFW
68RRFlyer Offline OP
DFW
Hi Guys,
I have a question in regards to a 68 Charger's power brake booster. Does the factory booster have the retaining strap that runs around the booster to sandwich the two booster halves together held in place by a long bolt that is subsequently bent to match the contour of the booster? You can see it on the booster in this pic at about the 9 o'clock position. Seems odd that the factory would bend a bolt like that, but maybe so. It still has some factory parking on it too. I took it apart to inspect/restore it and was just curious if I was wasting my time if it was a replacement. Thanks!
Cheers
Re: 68 Charger brake booster [Re: 68RRFlyer] #198762
01/20/09 12:31 PM
01/20/09 12:31 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That is the correct booster for power drum brakes in '68. I'll see if I can find my pics.
Re: 68 Charger brake booster [Re: 68RRFlyer] #198763
01/21/09 03:40 PM
01/21/09 03:40 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
That looks like a Bendix booster that would be used on disc brake cars. It appears to have the original drum brake master cylinder attached (Disc brake master cylinders have the lines attaching from the inboard side of body).
Here is a pic of an original booster on a power drum 1968 Charger 383 4V. It is the flat type which is crimped together.
Re: 68 Charger brake booster [Re: 70mopes] #198764
01/21/09 04:41 PM
01/21/09 04:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's the pic of the engine compartment on my '68.
326 SPD, Hamtramck assembled, 383 4bbl with the heavy-duty 11" brakes:
