How to put an LA intake on a magnum #198705
01/20/09 01:42 AM
01/20/09 01:42 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
A bunch of people want to know how I made my own jig so here goes.
To build on you need...
1 LA head of any kind.
1 Piece flat stock 1/4 by 2" about 14 inches long.
1 tube with the same inside diamater as the drill bit you are going to use.
For tools you need...
1 welder
1 drill
2 (or more) welding clamps
1 drill bit
1 tap and driver.
I took a 2 inch wide 1/4 inch thick steel plate about 14 inches long and bent it at a sharp 90 degree angle about 4 inches from the end and with welding clamps clamped it to the chamber side of the head and marked a place for the LA bolt hole to go through and drilled it a little bigger than the bolt hole.
Second piece was a thick walled pipe about two inches long and it was a tight fit on the drill bit to keep it steady. Depending on what bolt hole size you use you need a different hole size in the pipe.
1st step in assembly was to put a bolt about 3 inches long through it all on an LA head to hold it at the proper angle. 2nd weld the pipe to the flat piece. Then you have a jig.
To drill the magnum head you clamp it on to the mag head on the chamber side of the head again with welding clamps and line it up with the mag bolt holes as they are all in the same places but different angles. I also use a clamp on the intake side to keep it from jumping around and screwing the job up.
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198706
01/20/09 01:44 AM
01/20/09 01:44 AM
Kalispell Mt.
Kalispell Mt.
Here is a pic against the head, I will see if I can find my clamps and get a shot of it clamped on there.
Also when you do the two end holes you need a spacer between the deck side of the head and the jig to make the holes lower like on an LA. I will measure my spacer I made so you can see how thick of one you need.
One clamp goes by my finger tips and the other at the other end down past my
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198707
01/20/09 01:54 AM
01/20/09 01:54 AM
Kalispell Mt.
Kalispell Mt.
You always need a good assistant.
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198708
01/20/09 09:56 AM
01/20/09 09:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
spacer size?
2017 Grand Cherokee Overland
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198709
01/20/09 12:11 PM
01/20/09 12:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good job, nice and simple
Re: How to put an LA intake on a magnum [Re: ZIPPY] #198710
01/20/09 04:09 PM
01/20/09 04:09 PM
Kalispell Mt.
Kalispell Mt.
I use two 19/64 drill bits for spacers or about .300 in"
I have always used a "3/8th NC16" tap and a set of LA intake bolts. I think the drill bit is a 5/16
Tip, when you first start drillin into the magnum head there is a bit of a bur that can catch the drill bit so start slow and easy till you get past that.
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198711
01/20/09 05:13 PM
01/20/09 05:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why don't you make a few of them, type your instructions out and sell em for 30 bucks a pop. I bet there's a lot of guys who couldn't would wouldn't want to make their own. Helps them out plus puts a couple bucks in your pocket...
Re: How to put an LA intake on a magnum [Re: DaytonaTurbo] #198712
01/20/09 05:52 PM
01/20/09 05:52 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yeah good idea. to make them up and sell them. Crap; i had mine done at a local place (job shop not a regular machine shop) and told them to drill and tap directly perepndicular to the intake mount face. I hope that the angle mismatch between perp and where it should be wont be too much. If so I will have to have them redrilled O/S and put thread inserts in the heads (which I thought about anyway)
I'm gonna have to mock them up on the Magnum block, that I have on the stand.
Re: How to put an LA intake on a magnum [Re: DaytonaTurbo] #198713
01/20/09 05:54 PM
01/20/09 05:54 PM
scratchnfotraction Offline
I will take a set,jig and sacer
I will take the used drill bit also
just cause I cant make stuff and thats the reason I have not gone to mag heads yet...just cant see buying another intake when I have a few good ones now
Re: How to put an LA intake on a magnum [Re: HotRodDave] #198714
01/20/09 07:08 PM
01/20/09 07:08 PM
correct
Re: How to put an LA intake on a magnum [Re: DaytonaTurbo] #198715
01/20/09 07:53 PM
01/20/09 07:53 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
id buy one right now if he was selling them for 30 bucks.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
