Re: just a quick question flywheel bolts
[Re: dirtycj5]
#1986042
01/08/16 02:00 AM
01/08/16 02:00 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Cab, magnum engines have a one piece rear main seal, meaning there really isn't a crank flange like the motors us old guys run.
Rear crank flange/hub is pretty thick. I don't think a 1" bolt will hurt anything. Since the dealer has four in stock, grab one, measure it and order a set of APR flywheel bolts to those dimensions.
[image][/image]
[Re: dirtycj5]
#1986430
01/08/16 05:59 PM
01/08/16 05:59 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The aftermarket bolts that I've used were 7/16"-20 x 1"
[Re: dirtycj5]
#2022571
03/01/16 01:53 PM
03/01/16 01:53 PM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
just called the dealer they got 4 in stock lol. the funny thing is i remember buying a set form checkers years ago mr gasket brand for a chevy that fit my 383 in my coronet just fine i just cant remember the length of the bolts. thanks guys the search continues The chevy Bolts are 1" , Chrysler bolts are a little shorter, maybe 7/8" ? Make sure they don't stick to far out the back.
[Re: ahy]
#2022573
03/01/16 01:55 PM
03/01/16 01:55 PM
JohnRR
U.S.S.A.
FWIW I just got a set from Mancini. 7/16"x1". Its a BB but same type 130 tooth flywheel. They were not too long with or without lock washer though I did use a lock washer. What type of lock washer , factory might have used a thin star washer but not a standard split lock. If a split hopefully when the clutch has significant wear the clutch disc doesn't start hitting the bolt heads.
