Page 3 of 3 1 2 3
Re: Big block A-body guy's [Re: dartman366] #1985190
01/06/16 10:06 PM
01/06/16 10:06 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'm using the Pro Parts headers. This is my second set in about 30+ years. Original set we got thru Herb McCandless,new set thru Bob Mazzolini. The new Pro Parts style are made for Bob by TTI. They are very nice quality and better tubing.
Nautilus Racing-
Re: Big block A-body guy's [Re: ozymaxwedge] #1985266
01/06/16 11:44 PM
01/06/16 11:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By ozymaxwedge
Originally Posted By 67mprfan
Originally Posted By ProSport
The Hedman fenderwell headers that Sixpackgut mentioned are something that I always wanted to try as they made more power than anything else on several cars that I read about.
If you run the hedman fender well headers don't you also run into tire clearance issues where a taller tire will hit plus you can't make Sharp turns without them rubbing. I'm not sure just asking
Yes we have them on a Aussie A Body and they rub before you get to full lock, not real big problem on a part time street/drag car.
Headman
My buddy's car had a set just like those on his dart back in the late 70s, called, Headers by Ed, fit better than the hookers and more tire clearance. Changed plugs from underneath
Re: Big block A-body guy's [Re: dartman366] #1985282
01/07/16 12:01 AM
01/07/16 12:01 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I have used Pro Parts and TTI BB A body headers and IMO they both leave a lot to be desired. IMO it is worth they expense of getting headers built.
Re: Big block A-body guy's [Re: dartman366] #1985327
01/07/16 12:47 AM
01/07/16 12:47 AM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
You want stainless or steel? lol
Re: Big block A-body guy's [Re: Chad Bittle] #1985355
01/07/16 01:41 AM
01/07/16 01:41 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Hey he is going Big so go stainless - he has a budget (an unlimited budget) up
whistling
Re: Big block A-body guy's [Re: dartman366] #1985424
01/07/16 06:35 AM
01/07/16 06:35 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
sorry to be a pain in the azz i know this topic is about big blocks in a bodies but has any one used headman headers in a body but small block does the pipe that comes out the frame rail does it interfear with the steering thanks
Re: Big block A-body guy's [Re: dartman366] #1985426
01/07/16 07:01 AM
01/07/16 07:01 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
What I have tested, the Hookers are good for tq but limit peak power somewhat, the primaries are extremely long. TTI's are a pain, there really isn't room for underchassis headers, never used the Hedmans, have built my own fenderwells. The shock towers can be chopped and the top ends of the shocks moved outside for a little more room, and pushing the firewall a little back behind the wheels gives you enough room not to limit the tire size.
Plynouth VIP '67 TT IC EFI
Re: Big block A-body guy's [Re: one bad fish] #1985464
01/07/16 11:17 AM
01/07/16 11:17 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
no, not with a 26" tire. I am going to a 28" so I will see.
Re: Big block A-body guy's [Re: max_maniac] #1985468
01/07/16 11:34 AM
01/07/16 11:34 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
whistling
I heard this story before!
Re: Big block A-body guy's [Re: mopar dave] #1985490
01/07/16 12:29 PM
01/07/16 12:29 PM
bronx n.y
O
O
bronx n.y
can u send me a pic of the headers installed
Re: Big block A-body guy's [Re: DoubleD] #1985495
01/07/16 12:34 PM
01/07/16 12:34 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
whistling
Yes you have ---- where do you think I got it from coffee
Re: Big block A-body guy's [Re: max_maniac] #1985603
01/07/16 03:30 PM
01/07/16 03:30 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
whistling
Where the heck you guy's getting your info from!! shock
Re: Big block A-body guy's [Re: dartman366] #1985890
01/07/16 10:27 PM
01/07/16 10:27 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
I've got that kit to build 2" headers, Bill. I don't know if they'd be any good but we can try something. You want them between the frame rails, all the same length tubes, good clearance for easy spark plug removal and easy to get the bolts out...in an A Body? Sounds easy.
Re: Big block A-body guy's [Re: Chad Bittle] #1985926
01/07/16 11:21 PM
01/07/16 11:21 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
sound's about right,,,oh and don't forget easy installation with no loss of knuckle meat.LOL green
Re: Big block A-body guy's [Re: dartman366] #1985946
01/07/16 11:46 PM
01/07/16 11:46 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Piece of cake!
Re: Big block A-body guy's [Re: dartman366] #1985996
01/08/16 12:50 AM
01/08/16 12:50 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have to remove my engine plate to get the headers off in my new small tire car. Those STOCK firewall rules make things tough. LOL At least he was able to weld the collectors on so I don't have to buy those silly cable systems.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Big block A-body guy's [Re: dartman366] #1986068
01/08/16 02:35 AM
01/08/16 02:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We usually have to make a wrench for the plugs but otherwise they are somewhat pain free. Slip on collectors and install and removal is easy
Page 3 of 3 1 2 3
