Roller rockers- Hughes, T&D, Harland Sharp? #1984997
01/06/16 05:53 PM
01/06/16 05:53 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Wanting to buy a new set of roller rockers for my freshly built 418 smallblock. Has a .693 comp cam solid roller. Was thinking of going with Hughes rockers, just wanted to get some opinions from you guys who would you go with and had experience with. Hughes, T&D, Harland sharp? Thanks in advance. Brett
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985011
01/06/16 06:13 PM
01/06/16 06:13 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
T&D. Spend the money once. Follow the instructions to the letter for geometry and pushrod length.
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: fbs63] #1985018
01/06/16 06:19 PM
01/06/16 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.. I'll be using them on DW also
wave
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985111
01/06/16 08:19 PM
01/06/16 08:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've ran Hughes on a couple ft cams and have had no breakage even though they had to have a ton of clearence work to clear my Comp 930 springs. That being said I have T&D for my new build.
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985155
01/06/16 09:17 PM
01/06/16 09:17 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
That answers my question. Thanks for the reply guys
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985175
01/06/16 09:46 PM
01/06/16 09:46 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run T&D also (1.65 ratio)....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985237
01/06/16 11:12 PM
01/06/16 11:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Been running 1.6 Hughes for a few years now on my Magnum heads. No problems, but you are running a much more aggressive cam than I did / am.
Fastest 300
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: Crizila] #1985321
01/07/16 12:36 AM
01/07/16 12:36 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Once again the T&D's will be well worth the money. Buy them once and don't worry about them.
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985326
01/07/16 12:46 AM
01/07/16 12:46 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have a set of the newer Hughes 1.6's, they seem to be great and never need adjustment .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: ozymaxwedge] #1985368
01/07/16 02:21 AM
01/07/16 02:21 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
T & D here
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985514
01/07/16 01:22 PM
01/07/16 01:22 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
What are the T&D's going for now? Are they still $1100?
Has anyone tried out the new Scorpion Big Block Mopar rocker arms?
Adriel Paradise
Substation Design Engineer III
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1985520
01/07/16 01:35 PM
01/07/16 01:35 PM
USA
B3RE Offline
B3RE  Offline
USA
If you go with T&D, you will want the paired system, but I'm guessing you want a single shaft system since it sounds like the motor is already built. The geometry won't be correct on any single shaft system unless the shafts are relocated, regardless of pushrod length or roller to valve tip contact location. That goes for any brand roller rocker.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: Stroker Scamp] #1987489
01/10/16 12:59 PM
01/10/16 12:59 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Originally Posted By Stroker Scamp
T & D here
T&D here also.... Excellent service and turnaround
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1987491
01/10/16 01:02 PM
01/10/16 01:02 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've run H/S in my big block without any failures on a .660" lift roller cam. You have to run hard shafts (usually supplied with their kits) and you might want to restrict the oil feed a little since the needle bearings allow for a lot of flow.
[image][/image]
Re: Roller rockers- Hughes, T&D, Harland Sharp? [Re: 416scamp] #1987787
01/10/16 06:49 PM
01/10/16 06:49 PM
I've used all three of those brands single shafts for and on BB roller cam motors with similar lift. I won't use the cryo treated Hughes rockers again after having issues with thier adjusters and nuts, they wouldn't stay tight down Same thing using the better high dollar race Manton adjusters staying tight in those rocker arms also runaway On Harlnad Sharps compared to the T&D single shafts I like and use the Harland Sharps now on most application due to the better customer service and rebuilding services later after racing and using them both work I saw around .025 to .035 lift differences on both sets at the retainers shock shruggy I have a set of Indy 440-1 heads that I bought from a member on here that came with a set of new Jesel paired shaft rockers with 1.55 ratio, I've mocked up one pair on one head with checking springs to find out how long the pushrods need to be, no problem so far but no run time either yet so no real feed back either shruggy I'll probally run them the way they way they are now (I had to add a .060 spacer to get them aligned properly per the instructions from Jesel) for a while and maybe change the rockers to .175 or 1.8 ratio next winter workIHTHs thumbs
