Where to hide Electronic Ignition Box? #198430
01/19/09 08:43 PM
01/19/09 08:43 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Hello! Where are you folks hiding your electronic ignition boxes? Under the dash, I assume? I'm "fixing up" my '70 Swinger and want to make it look a little more "stock".
Thanks for any ideas!
Stan
Re: Where to hide Electronic Ignition Box? [Re: HemiStan] #198431
01/19/09 09:08 PM
01/19/09 09:08 PM
BRawls Offline
super gas
BRawls  Offline
super gas
I put mine on the bottom of the battery tray in a '70 Road Runner. Still gets some air flow there to help it stay cool.
Re: Where to hide Electronic Ignition Box? [Re: BRawls] #198432
01/19/09 09:35 PM
01/19/09 09:35 PM
southern in.
72sebring Offline
72sebring  Offline
southern in.
i put mine in the stock location if you use mopar performane ign it looks just like the old regulator
Re: Where to hide Electronic Ignition Box? [Re: BRawls] #198433
01/19/09 09:41 PM
01/19/09 09:41 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Re: Where to hide Electronic Ignition Box? [Re: rrunner] #198434
01/19/09 10:07 PM
01/19/09 10:07 PM
MA
440beeper Offline
440beeper  Offline
MA
There's company on eBag that sells an ECU bracket that mounts on the rear of the engine (rear intake valley hold-down) on RB/B motors. Haven't used it, but I like of idea of not having to drill any holes.
Re: Where to hide Electronic Ignition Box? [Re: rrunner] #198435
01/19/09 10:12 PM
01/19/09 10:12 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
We put ours on the backside of the firewall where the heater box used to be. Out of the heat and weather. Lots of air moving through the cowl vents to keep it cool. Some people say that MSD boxes can make clicking sounds but we have never noticed.
We also got rid of the connector for the column wiring and replaced it with a terminal strip:
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Where to hide Electronic Ignition Box? [Re: 440beeper] #198436
01/20/09 06:54 AM
01/20/09 06:54 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I bought one of these to install on a buddy's road runner so I wouldn't have to hack holes in the firewall. Works quite slick I say. No need for 10 feet of wiring to get inside or under the battery tray. Even without a carb or air cleaner on it, it hides behind the manifold really well.
I can't afford this. mark
Re: Where to hide Electronic Ignition Box? [Re: a12superbee] #198437
01/20/09 10:24 AM
01/20/09 10:24 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
On the core support under the horn.
Re: Where to hide Electronic Ignition Box? [Re: pushbutton] #198438
01/20/09 03:46 PM
01/20/09 03:46 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the replies!
Has anyone else mounted theirs under the dash like David in St Croix? How hot does the MP ECU actually get?
Stan
Re: Where to hide Electronic Ignition Box? [Re: HemiStan] #198439
01/20/09 08:08 PM
01/20/09 08:08 PM
NJ
440challenger Offline
NJ
mines right under the dash under the heater box on the toe board where it angles up
Re: Where to hide Electronic Ignition Box? [Re: 440challenger] #198440
01/20/09 08:55 PM
01/20/09 08:55 PM
NC USA
71mopardude Offline
I don't get it?
71mopardude  Offline
I don't get it?
NC USA
i seen one i forget where but it was hidden inside the washer fluid jug !!! the bottom was cut the jug sides where painted blue.. I thought that was cool!!
Re: Where to hide Electronic Ignition Box? [Re: 71mopardude] #198441
01/20/09 09:05 PM
01/20/09 09:05 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i always put them on the passenger side kick panel area. gets air from the vent to keep em cool
Re: Where to hide Electronic Ignition Box? [Re: prochargedhemi] #198442
01/20/09 09:13 PM
01/20/09 09:13 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Mine is right on top of the center console behind the ashtray but facing the heater box, custom bracket, all nice and tidy and wires kept and clean. Have access to the RPM pill for easy swaps. I hardly turn on my heater so it doesnt get that warm but I wanted a clean engine bay and hardly any wires visible. I couldnt mount under the battery tray because I have a vaccuum assist motor under there
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Where to hide Electronic Ignition Box? [Re: Pyper70] #198443
01/20/09 09:41 PM
01/20/09 09:41 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
under the front bumper area or just in front of rad under front bumper good luck dan
Re: Where to hide Electronic Ignition Box? [Re: ph23vo] #198444
01/21/09 08:35 AM
01/21/09 08:35 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Not a good place....Sure the air cooling it down would be great but driving in the rain or going through a puddle? The last thing you need is a burned out electronic ignition due to shorting from water
