Need help ! 1970 Duster rocker panel molding clips ???? #1984325
01/05/16 06:14 PM
01/05/16 06:14 PM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
I have a 1970 Duster that has the 2 inch wide aluminum rocker panel moldings. A few of the clips are broken and I am in desperate need of some replacements. I have searched every website that I can think of and cannot locate any. Classic Industries is now apparently repopping the moldings but not the hardware ? If anyone has any for sale or can point me in the right direction I would be forever grateful- Thanks in advance, Ron
1970 Plymouth Duster 1971 Dodge Challenger 2009 Dodge Challenger R/T 1970 Dodge Dart Swinger 340 4 Speed (Son's) 1985 Chevrolet Corvette (Wife's)
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1984563
01/05/16 11:23 PM
01/05/16 11:23 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I'm installing those same moldings from Classic Industries on my '69 Cuda ( I have to shorten them a bit to fit)
I hunted around at various swap meets for clips and found 2 different p/n's that will work: 6003576 and 6003775
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1984614
01/06/16 12:14 AM
01/06/16 12:14 AM
BlueRacer69 Offline
BlueRacer69  Offline
Did you try R/T Specialty? I think the guys name was Tom Race or something. I got rocker molding clips for my 69 Dart from him a few years back.
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1984625
01/06/16 12:36 AM
01/06/16 12:36 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
These are what originally came with 1971 Duster Rocker moldings. The plastic clips were used from the rear forward, the metal clip was only used in the final forward location on the fender dog leg. I don't know of any reproduction source for either clip.
I have not seen a 1970 wide style in person, it may have been the same?
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: ScottSmith_Harms] #1985217
01/06/16 10:44 PM
01/06/16 10:44 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Scott
That plastic clip don't seem to be wide enough to hold the 2" wide moldings - based on a measurement I took on an original and repro molding????
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1985218
01/06/16 10:45 PM
01/06/16 10:45 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Can you post a photo of the clips you have??
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: RealWing] #1985798
01/07/16 07:47 PM
01/07/16 07:47 PM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
Thank you so much
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: RealWing] #1985800
01/07/16 07:47 PM
01/07/16 07:47 PM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
I will take some photos and post them soon- thanks for all your help
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: RealWing] #1985801
01/07/16 07:49 PM
01/07/16 07:49 PM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
Realwing- the clips that you are using- did you order them from classic industries also ??
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1986285
01/08/16 02:33 PM
01/08/16 02:33 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
NO- I picked them up at a swap meet. They are a little wide, so I suspect they have to be trimmed a bit to fit in the groove.
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: mopar155] #1986641
01/09/16 12:37 AM
01/09/16 12:37 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
RealWing, would you let me know how those clips work out for you?
Am looking for some clips for my 69 as well.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: BloFish] #1987014
01/09/16 05:53 PM
01/09/16 05:53 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Will do. It may be a while (couple of months) before I'm ready to install.
Re: Need help ! 1970 Duster rocker panel molding clips ???? [Re: RealWing] #2078445
05/22/16 09:07 PM
05/22/16 09:07 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
They didn't work. They were too wide and would not snap into the groove in the trim. I finally resorted to using polyurethane adhesive to hold the trim in place.
http://www.forabodiesonly.com/mopar/threads/srt8cuda-build.218445/page-21
