Window net Installation pics #1983476
01/04/16 03:53 PM
01/04/16 03:53 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Everybody,
I need some help on the best way to install a window net. The car does have a funny car cage so it will be a 10" net. I'm looking for installation ideas.
Rods bottom and top or something different.
Re: Window net Installation pics [Re: Biginchmopar] #1983828
01/04/16 11:22 PM
01/04/16 11:22 PM
ky
68roadrunner Offline
ky
dont have any pics, but put the rod in the front up and down so you can bend it out toward the window some to keep it off your arm. then at the back screw it to the f/c cage with some 10/32 button head screws
i order a custom size from stroud so it fits nice
good luck hope this helps
Re: Window net Installation pics [Re: Biginchmopar] #1983852
01/04/16 11:45 PM
01/04/16 11:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Hold your helmet up against the inside of the front and rear (main hoop) funny car cage bars. Hold a straight edge across the outside of the bars. If your helmet can touch the straight edge at any point you try between the bars, they may want the net to extend back to the main hoop. Or you can add/re-position tubing to keep the helmet completely inside the cage.
Typical net in that application is attached to the door bar at the bottom with a bracket and small screws and at the top with seat belt style buckles on the front and rear of the net. Release the buckles and the net falls down completely out of the way. It's going to be a custom deal.
Re: Window net Installation pics [Re: Biginchmopar] #1983877
01/05/16 12:13 AM
01/05/16 12:13 AM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
This is what I did.. I bent the 5/16 moly to follow The cage. It gives you more arm room. I also bought clevis's to put on the rod towards the back and tapped the fowarded one for the heim to pivot on.
Re: Window net Installation pics [Re: Biginchmopar] #1983879
01/05/16 12:15 AM
01/05/16 12:15 AM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
Re: Window net Installation pics [Re: Biginchmopar] #1983889
01/05/16 12:38 AM
01/05/16 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you send a cardboard template to RJS they will
make any custom size or shape net.. make sure you
get the ribbon one(pretty sure its the ribbon one
that doesnt expire)
EDIT
mark what edge/edges will have a rod so they know where
to fold and sew it
http://www.rjsracing.com/
wave
Re: Window net Installation pics [Re: rgreule] #1983945
01/05/16 02:09 AM
01/05/16 02:09 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Nice car! It may never be mentioned by a tech guy but fyi the IHRA net requirements state that the net must extend forward to within 2 inches of the rearmost part of the steering wheel. Last time I checked NHRA did not have the same requirement.
Re: Window net Installation pics [Re: Biginchmopar] #1984207
01/05/16 03:40 PM
01/05/16 03:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No pics(in DC) but on my Stratus it is attached on the door bar with rivets and a piece of stainless. The top is attached with two seat belt buckles. Simple and easy and came that way from RJ. It drops completely out of the way for ingress and egress. Which is a plus since there is a very small space in get in and out through.
On the Cuda we have a tube on the bottom of the net that is bolted into tabs on the door bar, tube adapters in tube ends to allow for bolts. The top is on a tube that slides through another tube at the back and a buckle up front. That way it drops completely out of the way for getting n and out.
Re: Window net Installation pics [Re: Al_Alguire] #1984658
01/06/16 01:25 AM
01/06/16 01:25 AM
Carson City, Nevada
Carson City, Nevada
Thanks all!
Any pictures of the duel belt buckle Al would be much appreciated.
Trying to figure out a couple small things like this is time consuming.
Re: Window net Installation pics [Re: Biginchmopar] #1984683
01/06/16 01:51 AM
01/06/16 01:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Biginchmopar
Thanks all!
What Al shows with the ring and buckle is how mine
is also.. then on the lower its a bar with 2 rings
with a clip at each end
wave
Re: Window net Installation pics [Re: Biginchmopar] #1984686
01/06/16 01:53 AM
01/06/16 01:53 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unfortunately no..I am in DC for the next few months so not near the car. It is at paint camp right now but about ready to come home smile
Looks basically like the Cuda, only the bottom is secured with a piece of stainless steel that is secured with 6 screws tapped into the door bar. The stanless secures the lower part of the net with the screws through it. Instead of one buckle up top there are two, one on each end
Re: Window net Installation pics [Re: Biginchmopar] #1984702
01/06/16 02:15 AM
01/06/16 02:15 AM
baldwinsville new york
a493demon Online content
a493demon  Online Content
I don' have a F/C cage in mine but this is what I used.
think it might work with the F/C if you mount it up and down .
You would have to check length on it though.
http://www.summitracing.com/parts/vms-700101/overview/
Re: Window net Installation pics [Re: a493demon] #1989290
01/12/16 03:41 PM
01/12/16 03:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Here is mine in the Challenger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Window net Installation pics [Re: 6PKRTSE] #1989291
01/12/16 03:43 PM
01/12/16 03:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
From the inside keeping the all Mopar theme I re-used one of my old factory seat belt buckles.
