Re: Window net Installation pics
[Re: Biginchmopar]
#1983852
01/04/16 11:45 PM
01/04/16 11:45 PM
Posts: 11,572 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Hold your helmet up against the inside of the front and rear (main hoop) funny car cage bars. Hold a straight edge across the outside of the bars. If your helmet can touch the straight edge at any point you try between the bars, they may want the net to extend back to the main hoop. Or you can add/re-position tubing to keep the helmet completely inside the cage. Typical net in that application is attached to the door bar at the bottom with a bracket and small screws and at the top with seat belt style buckles on the front and rear of the net. Release the buckles and the net falls down completely out of the way. It's going to be a custom deal.
[Re: Biginchmopar]
#1983889
01/05/16 12:38 AM
01/05/16 12:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you send a cardboard template to RJS they will make any custom size or shape net.. make sure you get the ribbon one(pretty sure its the ribbon one that doesnt expire) EDIT mark what edge/edges will have a rod so they know where to fold and sew it http://www.rjsracing.com/
[Re: Biginchmopar]
#1984683
01/06/16 01:51 AM
01/06/16 01:51 AM
MR_P_BODY
Thanks all! Any pictures of the duel belt buckle Al would be much appreciated. Trying to figure out a couple small things like this is time consuming. What Al shows with the ring and buckle is how mine is also.. then on the lower its a bar with 2 rings with a clip at each end
[Re: Biginchmopar]
#1984686
01/06/16 01:53 AM
01/06/16 01:53 AM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Unfortunately no..I am in DC for the next few months so not near the car. It is at paint camp right now but about ready to come home Looks basically like the Cuda, only the bottom is secured with a piece of stainless steel that is secured with 6 screws tapped into the door bar. The stanless secures the lower part of the net with the screws through it. Instead of one buckle up top there are two, one on each end
[Re: a493demon]
#1989290
01/12/16 03:41 PM
01/12/16 03:41 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Here is mine in the Challenger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1989291
01/12/16 03:43 PM
01/12/16 03:43 PM
6PKRTSE
Motor City
From the inside keeping the all Mopar theme I re-used one of my old factory seat belt buckles.
