Re: mopar performance porting templates
[Re: SCATPACK 1]
#1982380
01/02/16 11:31 PM
01/02/16 11:31 PM
RapidRobert
The ones pictured in Pittsburgracers post are the ones I sent out to mgoblue today
[Re: mgoblue9798]
#1983031
01/03/16 09:33 PM
01/03/16 09:33 PM
Posts: 3,505 DFW
mr_340
DFW
Any chance to having them posted to the Tech Archives? That would be a good place to put a 1:1 PDF or JPG file that could be downloaded by all interested parties.
Floyd Lippencott IV
[Re: mr_340]
#1983162
01/04/16 12:12 AM
01/04/16 12:12 AM
RapidRobert
I have copies of mine (the BB MP ones) only several pages but I cant get the camera to link up with my windows 7 computer to post pics of em. Is there something else/another way I can help?
[Re: RapidRobert]
#1985994
01/08/16 12:47 AM
01/08/16 12:47 AM
RapidRobert
I have xeroxed copies of the MP BB and mag ones on white copy paper in front of me. If someone can use these to post em for everyones benefit get back to me
[Re: RapidRobert]
#1986225
01/08/16 12:50 PM
01/08/16 12:50 PM
DaytonaTurbo
Manitoba, Canada
I have xeroxed copies of the MP BB and mag ones on white copy paper in front of me. If someone can use these to post em for everyones benefit get back to me If you have digital copies of them, or paper copies, I would be more than happy to find a way to post them online for everyone to benefit.
[Re: DaytonaTurbo]
#1986741
01/09/16 03:15 AM
01/09/16 03:15 AM
RapidRobert
I have paper copies from the copy machine. send me an email with your mailing address & I'll get em out to you. Put "Templates" in the sub. rapidrobert at intergate dot com
[Re: mgoblue9798]
#1989039
01/12/16 02:21 AM
01/12/16 02:21 AM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I have the MP P4876412 templates for the small block cast iron swirl-heads. The instructions call out castings 308 & 576, however, I used them pretty successfully on my 596 castings. Let me know if you want the instructions, as the methodology to follow/apply the templates may be the same? For that matter, if anyone else wants these post in the thread and I'll upload the files, they are JPG images, although a bit large at about 3.4Meg each...so maybe attachement might not work...
Now, speaking of porting templates, does anyone have W2 templates??? LOL...was there such a thing ever made?
[Re: Diplomat360]
#1989254
01/12/16 02:55 PM
01/12/16 02:55 PM
RapidRobert
Diplomat I have a copy of those (412) templates right in front of me so why dont I save you the trouble and I will include em in the folder of BB/mag templates that I am going to send to our Canadian brother today.
[Re: mgoblue9798]
#1989862
01/13/16 01:51 PM
01/13/16 01:51 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Fwiw, regarding the BB templates....., I had a member here send me a set of stage v heads he template ported using the stage v specific templates. He also cleaned up the entire runner a bit. These heads also had 2.14/1.81 valves installed. The result was probably the most time intensive set of 245cfm big block heads around. A decent basic bowl blend and valve job, with some very minor short turn blending will get a set of 346/902/452 heads into the 260 range for a fraction of the time investment. Without some reworking of the short turn, you're only going to get so much flow out of those heads....... And frankly, that's not going to be a very big number. On the other hand, the templates will keep you from taking too much out of an area you shouldn't.
[Re: fast68plymouth]
#1990709
01/14/16 04:07 PM
01/14/16 04:07 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
Fwiw, regarding the BB templates....., I had a member here send me a set of stage v heads he template ported using the stage v specific templates. He also cleaned up the entire runner a bit. These heads also had 2.14/1.81 valves installed. The result was probably the most time intensive set of 245cfm big block heads around. A decent basic bowl blend and valve job, with some very minor short turn blending will get a set of 346/902/452 heads into the 260 range for a fraction of the time investment. Without some reworking of the short turn, you're only going to get so much flow out of those heads....... And frankly, that's not going to be a very big number. On the other hand, the templates will keep you from taking too much out of an area you shouldn't. I sent Dwayne a set of 906's i bought that were template ported, luckily with stock valve sizes still, figuring they would take less time to port because someone else had already started ...and save me a few bucks ... wrong ...
[Re: mgoblue9798]
#1990730
01/14/16 04:49 PM
01/14/16 04:49 PM
fast68plymouth
So. Burlington, Vt.
I've said it many times before...... The best bang for your porting buck on a BB are the 346/902/452 heads, especially if it's your first time. The MP instructions are to not mess with the short turn, and on a 906/915 intake port you're going to be lucky to get near 250cfm if you adhere to those instructions. I think the reason they tell you that is because it's really easy to get it wrong. The flatter floor on the newer style intake port will benefit from a mild blending from the floor into the bowl. On a 906 head, that gets you almost nothing. It's much easier/quicker to get the newer heads to flow 255-260 than the 906/915(or stage v for that matter).
#1991455
01/15/16 07:45 PM
01/15/16 07:45 PM
Thumperdart
State of confusion
I've said it many times before...... The best bang for your porting buck on a BB are the 346/902/452 heads, especially if it's your first time. The MP instructions are to not mess with the short turn, and on a 906/915 intake port you're going to be lucky to get near 250cfm if you adhere to those instructions. I think the reason they tell you that is because it's really easy to get it wrong. The flatter floor on the newer style intake port will benefit from a mild blending from the floor into the bowl. On a 906 head, that gets you almost nothing. It's much easier/quicker to get the newer heads to flow 255-260 than the 906/915(or stage v for that matter). Was thinking the same thing cos after all, that was a LONG time ago and lot`s has changed in every aspect of hot rodding. FWIW my Vicroy ported 906`s went 278-221 iirc and pushed my junk to 10.40`s and was my daily driver for years..............
[Re: RapidRobert]
#1992364
01/17/16 01:59 AM
01/17/16 01:59 AM
Diplomat360
Windsor, ON, Canada
RapidRobert! Diplomat I have a copy of those (412) templates right in front of me so why dont I save you the trouble and I will include em in the folder of BB/mag templates that I am going to send to our Canadian brother today. Tried to send you a PM, but forum tells me you're over the limit...LOL. Sure, I'd love to eye-ball these things...can you PM me with your email info? Thanks!
