big block in a dodge aspen #1981899
01/02/16 12:41 PM
01/02/16 12:41 PM
Denair,Ca
Armdropdart68 Offline OP
Denair,Ca
does anyone make headers for a 383/400 that will fit in an aspen.they can be fender well fender exit doesn't matter.
Re: big block in a dodge aspen [Re: Armdropdart68] #1981911
01/02/16 12:59 PM
01/02/16 12:59 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I really get the feeling that you are going to be "Trial and Error" on this. Maybe a set of A body fender wells. Can you get hold of a beat up set cheap, to use as a test fit? You will probably be spending plenty of time either making something fit or custom build a set.
[image][/image]
Re: big block in a dodge aspen [Re: Armdropdart68] #1981923
01/02/16 01:16 PM
01/02/16 01:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I put the schumacher tri-y headers on a 400 with raised port stage 6's. They sure are a bit restrictive and a little pricey, , but they fit.
Re: big block in a dodge aspen [Re: buildanother] #1982105
01/02/16 04:32 PM
01/02/16 04:32 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
This might be an interesting website to check out for possible info;
http://www.forfmjbodiesonly.com/classicmopar/
Re: big block in a dodge aspen [Re: buildanother] #1982188
01/02/16 07:08 PM
01/02/16 07:08 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
It's my understanding that B body headers will work, but you might need to beat on or modify the tube for #7 to clear the steering shaft. The upside to these cars is you don't have torsion bars in the way.
Re: big block in a dodge aspen [Re: Armdropdart68] #1982428
01/03/16 12:08 AM
01/03/16 12:08 AM
iirc one of the Mopar mags did a swap with that years ago, Volare maybe, the one with the front subframe buscuit mts that they replaced with solid ones and I think they modded at least one tube
Re: big block in a dodge aspen [Re: Armdropdart68] #1982759
01/03/16 03:54 PM
01/03/16 03:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not an Aspen but Chrysler Lebaron the small one.My buddys brother put a 392 Hemi in one.Took some work but it went in.I had some pics but lost them on the old computer.Rocky
Chrysler Firepower
