Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Preferneces on cage design? [Re: sgcuda] #1981740
01/02/16 02:06 AM
01/02/16 02:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The A-body cages ive been exposed to seem to have been bent to fit a Demon/Duster/Dart Sport but also "work" in Darts and Barracudas.
Mopar to the bone!!!
Re: Preferneces on cage design? [Re: sgcuda] #1981909
01/02/16 12:55 PM
01/02/16 12:55 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Cab; I'm still on the fence using chrome moly. My Snap-On mig welder does DC Tig, which I know I can use for steel, but I haven't figured out how to make it work yet. Probably because I never tig welded before. Can't figure out how to scratch start, keep glowing the electrodes when it sticks to the metal. I can arc weld, I can mig weld. Hopefully, I'm not too old to learn to tig weld.
Talking about safety, and knowing that a full tube setup changes how the car reacts, I do feel more comfortable using 2x3 frame rails, though. Is it cool to weld a c/m cage to a m/s frame setup?
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1981914
01/02/16 01:03 PM
01/02/16 01:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can weld M/S to moly.. BUT the first point that
is attached has to be tigged.. then from that point
on can be migged
wave
Re: Preferneces on cage design? [Re: sgcuda] #1981916
01/02/16 01:04 PM
01/02/16 01:04 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
What kind of tungsten are you using? 2% thoriated is my favorite for all metals, 100% argon, sharpen your tungsten and 150ish on amps for .120" thickness.
Re: Preferneces on cage design? [Re: sgcuda] #1981918
01/02/16 01:08 PM
01/02/16 01:08 PM
sgcuda Offline OP
sgcuda  Offline OP
I figured any part that is attaching c/m would need tig. Would be nice to do the whole car tig, if I can figure this crap out. The only mod I need is an Argon bottle. I've been using my Mix bottle just for practice on scrap tubing. I don't know how many more youtube videos I can watch. It seems like a monkey can do this.
[image][/image]
Re: Preferneces on cage design? [Re: Chad Bittle] #1981920
01/02/16 01:10 PM
01/02/16 01:10 PM
sgcuda Offline OP
sgcuda  Offline OP
I think that's right on the tungsten. I have to check. It's been a while. I think those are the red tip ones?
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1981921
01/02/16 01:11 PM
01/02/16 01:11 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Yes sir.
Re: Preferneces on cage design? [Re: sgcuda] #1981924
01/02/16 01:17 PM
01/02/16 01:17 PM
sgcuda Offline OP
sgcuda  Offline OP
I really love welding, too. Maybe, due to the immediate satisfaction of a job well done. An engine, trans, rear end build takes time from beginning to end, but a cage is in your face "Look what I just did!" type of accomplishment. I have Sat/Sun off for the month of January. Next weekend, I'll hit up my welding supplier for a bottle of Argon, some more tungsten tips, and keep at it.
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1981930
01/02/16 01:22 PM
01/02/16 01:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use the one Amp per one thousandths rule. .082 would be 82 amps.
Re: Preferneces on cage design? [Re: sgcuda] #1981933
01/02/16 01:27 PM
01/02/16 01:27 PM
sgcuda Offline OP
sgcuda  Offline OP
Well, my machine is a 140 amp unit, so I have that covered, weather c/m or m/s.
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1981935
01/02/16 01:31 PM
01/02/16 01:31 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
I remember being so pi$$ed off I wanted to quit my job trying to teach myself to tig weld. I was literally talking out loud to myself....why am I doing this if you can't even weld? lol It takes seat time and after long it will be like second nature. I agree with fastmop, I do autocad and waterjet cutting all day so I deal with measurements in thousands, so 1/8" thick is .125", so set my amps at 125-130 so I don't blow a hole thru my material. Just easier for me that way. I read your post about losing a loved one....that's one reason I made myself learn fab/welding. If someone else can do this, so can I. My best buddy that died from cancer and battle buddies that never came home Iraq would be calling me a little b!tch for giving up so easy...
Re: Preferneces on cage design? [Re: Cab_Burge] #1981939
01/02/16 01:36 PM
01/02/16 01:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By Cab_Burge
Step up and buy a chromemoly kit or have a custom chromemoly cage put in the car now up twocents What is your life and body parts worth if you end up testing the cage like happened to Big Cheif on his street outlaw car work Chromemoly has memory, mild steel does not work If you race a lot chromemoly will out live mild steel by a bunch, a freind of mine found that out the hard way. He wore out a fast power adder mild steel car in less than three years of racing no more than 12 times a year, 10 or less runs per race work I'm sure you don't want to hear about removing the roof to make the complete welds on all the roof bars but it is really worth it upDo it right once thumbs
Cab, I had my 64 Savoys roof off in three hours, fingering out how to do it as I went along.
Just the skin.
Re: Preferneces on cage design? [Re: MR_P_BODY] #1982002
01/02/16 03:29 PM
01/02/16 03:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
on can be migged
wave
You mean MS from that point on, just to be accurate. Correct?
Re: Preferneces on cage design? [Re: sgcuda] #1982138
01/02/16 05:52 PM
01/02/16 05:52 PM
sgcuda Offline OP
sgcuda  Offline OP
The frame rails are m/s. Where the cage c/m attaches to the frame, must be tigged. All cage joints must be tigged. Frame connections to body, and any m/s crossmembers can be migged.
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1982206
01/02/16 07:33 PM
01/02/16 07:33 PM
I can relate to the lack of welding skills, I've been blessed most of my life by having excellent welders and fabricators around thet would do any welding or fab work I needed on any of my car projects. I have several 220 buzz boxes, a 110 Craftsmen Mig welder and a Miller 180 or 185 Synchrowave combination tig and AC welder. I took several welding classes at the local J.C. industrial arts program and my welding on all types still looks like I [censored] it together out of my nose blush I don't plan on welding a cage or chassis together but it is nice to be able to weld thin metal together when needed instead of loading that project up and hauling it to a good welder blush I'll probally retake the Tig 1 welding class over again as I didn't get to finsh it the first time due to taking two welding classes in the same semester realcrazy
Re: Preferneces on cage design? [Re: jcc] #1982215
01/02/16 08:14 PM
01/02/16 08:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
on can be migged
wave
Yep..if you have moly and want to attach mild to it
that first joint must be tigged.. then the rest of
the mild can be migged... now if you are going mild
to moly then the whole thing needs to be tigged(as
in main rails are mild and you want to attach moly
then every point needs to be tigged).... on the welder
I run the machine on the high side being I use a foot
controller... some are saying 1 amp per .001, I leave
it about 125 or so on .083 moly... that way I can control
the output instead of being wide open on the pedal... I
use 3/32 tungsten with the red tip... just about 100% of
the time I use 1/16" steel rod.. I have used SS rod on moly
but its not necessary
wave
Re: Preferneces on cage design? [Re: sgcuda] #1982217
01/02/16 08:19 PM
01/02/16 08:19 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I kinda lucked out, bought a used Miller 180 Syncrowave from a guy who was a welding instructor, so he started me out on steel first, gave me homework and seat time. He was out the other nite and started me out on aluminum. I was like you and couldn't strike an arc to save my a$$, he showed me some tricks and then I actually liked doing it and look forward to practice. Might be worth your time to find some one to get you started, sure worked for me.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Preferneces on cage design? [Re: sgcuda] #1982224
01/02/16 08:25 PM
01/02/16 08:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Airco as a new tungsten rod out now, is not radioactive, seems to weld better all around, last quite well and don't have to grind as much. When I get home I'll update the name.
Re: Preferneces on cage design? [Re: sgcuda] #1982229
01/02/16 08:30 PM
01/02/16 08:30 PM
sgcuda Offline OP
sgcuda  Offline OP
cudaman1969: thanks for the info and any updates you can give me. I'll look into it with my local Airgas supplier. They were closed today, so no go on the Argon. Monday will be here soon enough.
[image][/image]
Re: Preferneces on cage design? [Re: sgcuda] #1982233
01/02/16 08:39 PM
01/02/16 08:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you haven't used argon you'll be pleasantly supprized on what a difference it makes. I clean well then heat with a butane torch and watch the moisture come out of the tube, hard to believe till you see it, dry tube makes a good weld. Leave a small hole for the air inside also.
