97 Dodge Dakota #1981068
01/01/16 02:28 PM
01/01/16 02:28 PM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
I'm looking at picking up a very clean 97 Dodge Dakota, 4x4, extended cab or is it club cab....very clean no rust. It has the V8 magnum engine, which is the 318 I believe. Mileage at just under 200k, which is 120 for you U.S folks.
I have no experience with the Daks, any advice or things to look for?
What are the weaknesses or faults of this model dak?
From all appearances the truck has spend a lot of its life indoors when in use and when not in use.
Thanks,
Re: 97 Dodge Dakota [Re: Lugnutz] #1981156
01/01/16 03:51 PM
01/01/16 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Re: 97 Dodge Dakota [Re: Lugnutz] #1981159
01/01/16 03:54 PM
01/01/16 03:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Hard to find one w/out rust being it's so old now. I just got a 98 ext cab 4x4 318 with low miles but does have rust. Replaced all the brake lines just about. The rockers are starting to go as well as the fenders. The frame even has a spooky swelling happening where the main frame joins rear section. (yes 2 pieces). Good truck for the most part.
Re: 97 Dodge Dakota [Re: Lugnutz] #1981561
01/01/16 10:28 PM
01/01/16 10:28 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have a 97 2wd E-cab. Pushing 300K Colorado miles and no rust. Has been one the best trucks that I've over owned.
Check for worn ball joints as they were shot from the factory. They also had a defective intake gasket. The heater core is probably clogged up too.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 97 Dodge Dakota [Re: Lugnutz] #1981645
01/02/16 12:11 AM
01/02/16 12:11 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I promise a 97 Dakota that spent its life in Northern IL would not look like that under it. A lot of them around here have rust holes in both bumpers, all 4 wheel wells, rockers, and door bottoms! Most run great though. 97 was the first year for that body style.
When did they start putting the 4.7 in?
I have a 93 4x4. Great truck, but the rust is probably going to kill it. Mine has 155,000 miles on it. Gene
Re: 97 Dodge Dakota [Re: Lugnutz] #1981653
01/02/16 12:18 AM
01/02/16 12:18 AM
places
79powerwagon Offline
places
These are great trucks! If it's been cared for, you'll have it a long time!
The foggy headlights can be revived with a wet-sanding, some clear coat for plastic, and a good coat of wax. Don't buy new aftermarket replacements.
About the only things I see regularly on these when they come up for sale is a noisy rear end, and blown transmissions. The steering system frequently leaks, too.
Otherwise, rust rust rust rust rust!
I got lucky, bought mine for a song from a charity. It was a one-owner truck, and I've got 170,000 miles on it with NO issues at all!
Re: 97 Dodge Dakota [Re: Lugnutz] #1981655
01/02/16 12:20 AM
01/02/16 12:20 AM
places
places
BWT, my truck is a Wisconsin truck it's whole life...
Re: 97 Dodge Dakota [Re: moparmarks] #1981931
01/02/16 01:24 PM
01/02/16 01:24 PM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
WOW that is a clean truck.............looks like its a year old...
I'm told the front end, ball joints and components were changed and have less then 100 miles on them. Asked about rust and there is no body rot and the underside looks like its 4 years old, is a rural truck so not exposed to road salt.
Nice truck....
Re: 97 Dodge Dakota [Re: Lugnutz] #1983584
01/04/16 06:14 PM
01/04/16 06:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Most of em I see for sale for cheap have transmission troubles. The rest have rust troubles. If you're good on both those counts, snag it.
Re: 97 Dodge Dakota [Re: Lugnutz] #1983602
01/04/16 06:42 PM
01/04/16 06:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Don't ever put clear coat on your headlights! Wet sand them yes, depending on how bad they are determines what grit you start with but usually around 1000 grit, then 1500 grit then POLISH them with paint polish, then wax them, they will look like new and never peel.
