Re: 97 Dodge Dakota
[Re: Lugnutz]
#1981561
01/01/16 10:28 PM
01/01/16 10:28 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have a 97 2wd E-cab. Pushing 300K Colorado miles and no rust. Has been one the best trucks that I've over owned. Check for worn ball joints as they were shot from the factory. They also had a defective intake gasket. The heater core is probably clogged up too.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 97 Dodge Dakota
[Re: Lugnutz]
#1981653
01/02/16 12:18 AM
01/02/16 12:18 AM
Posts: 27,728 places
79powerwagon
places
These are great trucks! If it's been cared for, you'll have it a long time!
The foggy headlights can be revived with a wet-sanding, some clear coat for plastic, and a good coat of wax. Don't buy new aftermarket replacements.
About the only things I see regularly on these when they come up for sale is a noisy rear end, and blown transmissions. The steering system frequently leaks, too.
Otherwise, rust rust rust rust rust!
I got lucky, bought mine for a song from a charity. It was a one-owner truck, and I've got 170,000 miles on it with NO issues at all!
Re: 97 Dodge Dakota
[Re: moparmarks]
#1981931
01/02/16 01:24 PM
01/02/16 01:24 PM
Posts: 1,261 Canada
Lugnutz
Canada
I have a 97 2wd E-cab. Pushing 300K Colorado miles and no rust. Has been one the best trucks that I've over owned. Check for worn ball joints as they were shot from the factory. They also had a defective intake gasket. The heater core is probably clogged up too. WOW that is a clean truck.............looks like its a year old... I'm told the front end, ball joints and components were changed and have less then 100 miles on them. Asked about rust and there is no body rot and the underside looks like its 4 years old, is a rural truck so not exposed to road salt. Nice truck....
Re: 97 Dodge Dakota
[Re: Lugnutz]
#1983602
01/04/16 06:42 PM
01/04/16 06:42 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't ever put clear coat on your headlights! Wet sand them yes, depending on how bad they are determines what grit you start with but usually around 1000 grit, then 1500 grit then POLISH them with paint polish, then wax them, they will look like new and never peel.
