Intake Manifold exploded
#198143
01/19/09 03:10 PM
01/19/09 03:10 PM
Posts: 86 Switzerland
swissmopar
Switzerland
Hi, can anyone explain what happened inside my Intake Manifold? What can I do not to get the same a second time? I tried to start my 1965 Hemi Coronet and cranked the engine for 2 seconds - there was a nasty bang - my intake manifold was cracked ... It is a '65 Magnesium Intake, prepped by Dick Landy. Thank you for your help! Karl
Re: Intake Manifold exploded
[Re: swissmopar]
#198144
01/19/09 03:17 PM
01/19/09 03:17 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
one of the carbs was flooding, stuck float ect. a little trick to prevent that again is drill and tap in a relief valve like on supercharger intake, but the smallest lightest spring one you can get, put in back of manifold will never be seen, hope that was not an oe 64/65 cross ram ouch///
MOPAR OR NO CAR
[Re: hemigod426]
#198145
01/19/09 03:20 PM
01/19/09 03:20 PM
swissmopar
Switzerland
Yes, it was one!
[Re: FuryUs]
#198147
01/19/09 03:32 PM
01/19/09 03:32 PM
swissmopar
Switzerland
Looks like you blew the welds on your intake--must have been too much NAWZ--LOLMAXX!!! Bummer, dude...
Need a translation: NAWZ--LOLMAXX?
[Re: FuryUs]
#198148
01/19/09 03:35 PM
01/19/09 03:35 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Welds? It's magnesium.....That would be a little tricky!
As suggested above, once the intake has been repaired/replaced install a pop off valve (a small one installed into one of the intake bolt access plugs works well, add one in 2 different plugs to feel extra safe).
This is a common problem with cross ram cars on the street, they don't like all the idling around, even with well setup carbs excess fuel can puddle in the intake when not running at higher rpms and when the fuel gets ignited it goes boom.
[Re: ScottSmith_Harms]
#198149
01/19/09 04:31 PM
01/19/09 04:31 PM
Posts: 4,558 Montana
FuryUs
Montana
It was a joke. Jeez--don't you guys watch stupid movies. Translations: NAWZ would be super import dork for nitrous oxide. LOLMAXX!!! would be 'laughing out loud a lot'--two X's and three exclamation points more than just LOL. Man, try--just try--to make a stupid joke around here!
[Re: FuryUs]
#198152
01/19/09 05:54 PM
01/19/09 05:54 PM
Posts: 4,884 Michigan
MNobody
Would appear the person is Swiss and didn't understand your smart azzed comment's about something that was not at all funny
#198154
01/23/09 09:49 AM
01/23/09 09:49 AM
swissmopar
Switzerland
@Scott any idea where I can get the proposed pop-off valve which fits into the intake bolt access plugs? Thank you! Karl
[Re: 1_WILD_RT]
#198155
01/23/09 10:21 AM
01/23/09 10:21 AM
Posts: 3,916 usa
lewtot184
usa
FWIW that manifold is fixable, you just need to track down the right guy with the right equiptment...Theres a guy here in town that uses a laser for welding Magnesium, he also has a vacuum chamber for welding titanium...He doesn't work cheap but he can repair stuff that most would give up on...Go to your local welding supply, they would know who local might be qualified..
i used to work in a metal shop that had a guy who TIG welded magnesium.
