Intake Manifold exploded #198143
01/19/09 03:10 PM
01/19/09 03:10 PM
Switzerland
swissmopar Offline OP
Switzerland
Hi,
can anyone explain what happened inside my Intake Manifold? What can I do not to get the same a second time?
I tried to start my 1965 Hemi Coronet and cranked the engine for 2 seconds - there was a nasty bang - my intake manifold was cracked ...
It is a '65 Magnesium Intake, prepped by Dick Landy.
Thank you for your help!
Karl
Re: Intake Manifold exploded [Re: swissmopar] #198144
01/19/09 03:17 PM
01/19/09 03:17 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
one of the carbs was flooding, stuck float ect. a little trick to prevent that again is drill and tap in a relief valve like on supercharger intake, but the smallest lightest spring one you can get, put in back of manifold will never be seen, hope that was not an oe 64/65 cross ram ouch///
MOPAR OR NO CAR
Re: Intake Manifold exploded [Re: hemigod426] #198145
01/19/09 03:20 PM
01/19/09 03:20 PM
Switzerland
Switzerland
Yes, it was one!
Re: Intake Manifold exploded [Re: swissmopar] #198146
01/19/09 03:29 PM
01/19/09 03:29 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Looks like you blew the welds on your intake--must have been too much NAWZ--LOLMAXX!!!
Bummer, dude...
Re: Intake Manifold exploded [Re: FuryUs] #198147
01/19/09 03:32 PM
01/19/09 03:32 PM
Switzerland
Switzerland
Bummer, dude...
Need a translation: NAWZ--LOLMAXX?
Re: Intake Manifold exploded [Re: FuryUs] #198148
01/19/09 03:35 PM
01/19/09 03:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Bummer, dude...
Welds? It's magnesium.....That would be a little tricky!
As suggested above, once the intake has been repaired/replaced install a pop off valve (a small one installed into one of the intake bolt access plugs works well, add one in 2 different plugs to feel extra safe).
This is a common problem with cross ram cars on the street, they don't like all the idling around, even with well setup carbs excess fuel can puddle in the intake when not running at higher rpms and when the fuel gets ignited it goes boom.
Re: Intake Manifold exploded [Re: ScottSmith_Harms] #198149
01/19/09 04:31 PM
01/19/09 04:31 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Bummer, dude...
It was a joke. Jeez--don't you guys watch stupid movies.
Translations:
NAWZ would be super import dork for nitrous oxide.
LOLMAXX!!! would be 'laughing out loud a lot'--two X's and three exclamation points more than just LOL.
Man, try--just try--to make a stupid joke around here!
Re: Intake Manifold exploded [Re: swissmopar] #198150
01/19/09 04:34 PM
01/19/09 04:34 PM
AndyF Offline
AndyF  Offline
The factory cross rams tend to do that. They have very poor fuel distribution when cold so a backfire will often cause a small explosion. I had a Max Wedge crossram on my car years ago and it would often backfire during cold weather. It wouldn't start at all if the temp was below 50 degrees.
Usually guys keep their foot on the pedal when cranking so that an explosion can go out the carb rather than blowing up the intake. If the throttles were closed then the throttle blades in your carbs might be damaged also.
That is a major bummer, that backfire just ruined $$$ in parts for you.
Re: Intake Manifold exploded [Re: AndyF] #198151
01/19/09 05:35 PM
01/19/09 05:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That is what I was thinking held wide open backfire would have a relief.
Re: Intake Manifold exploded [Re: FuryUs] #198152
01/19/09 05:54 PM
01/19/09 05:54 PM
MNobody Offline
MNobody  Offline
Bummer, dude...
Translations:
Would appear the person is Swiss and didn't understand your smart azzed comment's about something that was not at all funny
Re: Intake Manifold exploded [Re: MNobody] #198153
01/19/09 07:03 PM
01/19/09 07:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW that manifold is fixable, you just need to track down the right guy with the right equiptment...Theres a guy here in town that uses a laser for welding Magnesium, he also has a vacuum chamber for welding titanium...He doesn't work cheap but he can repair stuff that most would give up on...Go to your local welding supply, they would know who local might be qualified..
Re: Intake Manifold exploded [Re: ScottSmith_Harms] #198154
01/23/09 09:49 AM
01/23/09 09:49 AM
Switzerland
Switzerland
@Scott
any idea where I can get the proposed pop-off valve which fits into the intake bolt access plugs?
Thank you! Karl
Re: Intake Manifold exploded [Re: 1_WILD_RT] #198155
01/23/09 10:21 AM
01/23/09 10:21 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i used to work in a metal shop that had a guy who TIG welded magnesium.
Re: Intake Manifold exploded [Re: 1_WILD_RT] #198156
01/23/09 10:49 AM
01/23/09 10:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Anyplace that would sell industrial machine supplies for products like air compressors should have them.
Re: Intake Manifold exploded [Re: ScottSmith_Harms] #198157
01/23/09 11:45 AM
01/23/09 11:45 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Volkswagen Bug machine shops weld magnesium engine cases every day. Don't know who would have more experience with magnesium welding.
