Upper/Lower Ball Joints #1981448
01/01/16 09:00 PM
01/01/16 09:00 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Does anyone with a straight-axle 2nd Gen 1500 4x4 get away with only replacing upper ball joints?
I've got side to side play in the uppers but the lowers seem pretty tight. Is it really necessary to do all 4 or can I just replace the two uppers only?
Mo' Farts
Moderated by "tbagger".
Re: Upper/Lower Ball Joints [Re: Grizzly] #1981504
01/01/16 09:39 PM
01/01/16 09:39 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
For the amount of work,I'd certainly just do em all.
Angry white pureblood male
Re: Upper/Lower Ball Joints [Re: Grizzly] #1981648
01/02/16 12:13 AM
01/02/16 12:13 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Someone must have already changed the bottom ball joints, they usually fail first. Gene
Re: Upper/Lower Ball Joints [Re: Grizzly] #1982486
01/03/16 01:41 AM
01/03/16 01:41 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Like to slap the Meathead Engineer at Dana upside the head for not machining a flat surface on both sides of the upper mount so you can drive the ball joint in straight. mad 3 effing hours to do one side.......... shout
Have I mentioned how much I despise these straight-axle Dodges? At least 20 times I'm sure since I bought this truck. down
Mo' Farts
