Re: Small block Quick time bell housing Q
[Re: Dartbloke]
#1981096
01/01/16 02:55 PM
01/01/16 02:55 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I have a Quicktime housing, also. Big block. Haven't mounted it yet, but noticed the same thing as you. I don't think it is a concern. I'm pretty sure I have seen a bunch of race designed starter motors that don't have a nose on them, either. Never heard of anyone having issues with this. Use good strength/fitting hardware. You should be ok. If you need any measurement comparisons, just send me a PM.
[image][/image]
[Re: Dartbloke]
#1981528
01/01/16 09:55 PM
01/01/16 09:55 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
On a stock transmission the starter nose helps you position starter. Sense the starter holes are sloppy the nose helps the starter to self position as you tighten it up.
The QuickTime block plate has a defined hole. The shoulder on the starter centers the starter in the hole.
After first doing the R5 bells I noticed the lack of nose support. Even thought about welding one in. After a full season of running without I made the previous conclusions.
[Re: Dartbloke]
#1981534
01/01/16 09:59 PM
01/01/16 09:59 PM
sgcuda
A stock starter has fairly large holes. I don't know about the HP type race starters. If those holes are more defined also, there shouldn't be a problem. I know the old Lakewood shields were a pretty sloppy fit, too. Which is why a nose support goes a long way.
[image][/image]
[Re: sgcuda]
#1981736
01/02/16 01:49 AM
01/02/16 01:49 AM
Leon441
Lynchburg, VA
The starter hole in the QuickTime block plate fits the starter really nice. There's no slop on my application.
If you have used a Lakewood and happen to switch to QuickTime. It's a lot better fit all the way around.
Now if I can only convince Ross that all Mopar dowels are .496". That would put them a step above most.
