Small block electric water pumps #1979430
12/30/15 05:08 PM
12/30/15 05:08 PM
CA.
RAY1969CARS Offline OP
CA.
Got some leftover Christmas money imagine that got some leftover Christmas money imagine that Need some input between the moroso and the Meziere not too sure which one to get this is my first one Would want something that's rebuild And high flow motor make will make around. 625 to 650 and a 100 shot I think you for your wisdom and opinion
Re: Small block electric water pumps [Re: RAY1969CARS] #1979436
12/30/15 05:14 PM
12/30/15 05:14 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
I don't have neither one I 4 got the name but mine works good no problem here
Re: Small block electric water pumps [Re: RAY1969CARS] #1979441
12/30/15 05:18 PM
12/30/15 05:18 PM
bronx n.y
O
O
bronx n.y
CSR that's it. Lol
Re: Small block electric water pumps [Re: RAY1969CARS] #1979445
12/30/15 05:22 PM
12/30/15 05:22 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have the morose with the blue motor. Still works great after 13 yrs. I have more shroud to water pump motor clearence with the morose.
Re: Small block electric water pumps [Re: rickraw] #1979446
12/30/15 05:24 PM
12/30/15 05:24 PM
CA.
CA.
Street or strip?? How much hp ???
Re: Small block electric water pumps [Re: RAY1969CARS] #1979448
12/30/15 05:31 PM
12/30/15 05:31 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Street & strip. About 720 ponies.
Re: Small block electric water pumps [Re: rickraw] #1979455
12/30/15 05:39 PM
12/30/15 05:39 PM
CA.
CA.
Is there a difference between the blue and the silver pumps ?????
Re: Small block electric water pumps [Re: RAY1969CARS] #1979467
12/30/15 05:53 PM
12/30/15 05:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Off hand, I don't know. U can make a call to find out. I run a wizard rad/w 4 pullers. Temp never goes over 190 no matter how hot it gets. Runs about 170 on the open highway.
Re: Small block electric water pumps [Re: rickraw] #1979515
12/30/15 06:38 PM
12/30/15 06:38 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I just ordered the same one from Wizard cool , how do like it?
Switched to the dark side...
Re: Small block electric water pumps [Re: JSR1485] #1979532
12/30/15 07:05 PM
12/30/15 07:05 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Best rad I ever bought. It does cost more but, it's an exact fit, their shroud fits perfectly & it works.
Re: Small block electric water pumps [Re: RAY1969CARS] #1979555
12/30/15 07:45 PM
12/30/15 07:45 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I talk to the Guys there and they said it should work out fine for my race car, As they say you get what you pay for , big difference in cost from a BS brand radiator and theirs
Re: Small block electric water pumps [Re: JSR1485] #1979561
12/30/15 08:00 PM
12/30/15 08:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For a race car your going WAY OVER KILL.. a 45gal
pump is over kill but thats what I have.. it even
works great on the street... I run a the fan that
most of the guys run on the street(it the chevy unit
thats all in one)cant remember the 3 letters of it and
with a adjustable thero switch on the fan so it never
sees over 200*.. if I want lower I can have it come on
earlier.. but I have zero problems with 200*
EDIT
Its a HHR fan/shroud assem.
wave
Re: Small block electric water pumps [Re: RAY1969CARS] #1979568
12/30/15 08:16 PM
12/30/15 08:16 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"IF".... I had to do it over again I would go with the TANK MOUNTED Mezier water pump. You would then get Andy F's front plate and only have two AN lines running to the front of the engine. This would free up TONS of room on the front of the engine for mounting fans etc...
http://arengineering.com/products/water-manifolds-for-small-block/
I currently run the Mezier like the CSR pump shown above on both of my small blocks, but have the fan mounted in front of the radiator due to space limitations. Having a "divorced" water pump would remedy that and still give ample room to access the crank for adjusting/checking valve train. Woulda..coulda..shoulda..
this is my iron head 360 and my W8 has the same pump for ease of switching between mills... as you can see, if I had one or two fans on the radiator it would be very tight. So tight that it would probably require them to be removed to crank the engine over with my long breaker bar. Maybe something you wouldn't require on a street/strip car, but right now I want the room to work.
Re: Small block electric water pumps [Re: RAY1969CARS] #1979620
12/30/15 09:00 PM
12/30/15 09:00 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run the ProForm electric pump with a Summit brand radiator. I drive it on the street and do not even have to turn my front mounted electric fan on. Never goes over 190*. Been running that way for about 4 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Small block electric water pumps [Re: RAY1969CARS] #1979685
12/30/15 10:28 PM
12/30/15 10:28 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I have the Moroso and like it. That said; if I woulda bought a meziere, I coulda got one of Andy's timing covers later and made life easier.
http://arengineering.com/products/sb-timing-chain-cover/
The Moroso is shorter than the Proform and helps w/ clearance issues.
Yeah, it's got a smallblock.
Re: Small block electric water pumps [Re: RAY1969CARS] #1979708
12/30/15 10:58 PM
12/30/15 10:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I agree that the radiator mounted Meziere would be awesome with Andy's setup.
I have a Meziere on mine and have been very happy. It did go down after a 14 years but I can't complain about that. They repaired it very quickly for a great price.
68 Barracuda Formula S 340
Re: Small block electric water pumps [Re: RAY1969CARS] #1979712
12/30/15 11:02 PM
12/30/15 11:02 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Ive got the Moroso unit pictured above I just took off. It's for sale if anyone is interested. I'm going remote mount.
Re: Small block electric water pumps [Re: RAY1969CARS] #1980128
12/31/15 02:15 PM
12/31/15 02:15 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have used Meziere pumps for years. Good parts, great service.
I had them make me a flex plate. It was not as hard as they thought and they sent me a partial refund. How many places will do that?
Bill
Re: Small block electric water pumps [Re: RAY1969CARS] #1980218
12/31/15 03:46 PM
12/31/15 03:46 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
On my Dart I used the Meziere pump and milled the timing cover flat so I don't need the plate. This gave me about 3/4" more room.
On my new project I really like the remote pump and using the motor plate threaded for fittings http://www.summitracing.com/parts/mez-wp116shd
"Just a Bracket car dressed up like a streetcar"
Re: Small block electric water pumps [Re: RAY1969CARS] #1980628
12/31/15 09:29 PM
12/31/15 09:29 PM
AndyF Offline
AndyF  Offline
I'd recommend a remote pump if you haven't purchased the pump yet. It frees up a lot of space and lets you run a bigger radiator or bigger electric fans.
You can go remote with the stock water pump housing or use one of my billet timing chain covers. You can also use a remote pump with a motor plate.
