Page 3 of 3 1 2 3
Re: Stock stroke 360 on the dyno [Re: Streetwize] #949297
03/14/11 02:19 PM
03/14/11 02:19 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'm still scratching my head as to why I pulled out a perfectly good 341" (3.91" 318 factory roller block with an MP 3.55" 4340 stroke) to put in the 414, I'll bet this puppy made about 440hp (PLENTY!!) with a 236/240@.050 Hyd Roller and stock E-heads.
I've been doing the same thing.....I thought you were crazy to dump that motor
it's not like Rocky needed more TORK!
2017 Grand Cherokee Overland
Re: Stock stroke 360 on the dyno [Re: patrick] #949298
03/14/11 02:24 PM
03/14/11 02:24 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
LOL Patrick, yeah every time I trip over the "extra" motor in my limited garage I realize what a head-case I am!
The 414 $$ deal just kind of was an offer I couldn't refuse
WIZE
In Car:
Re: Stock stroke 360 on the dyno [Re: Streetwize] #949299
03/14/11 02:28 PM
03/14/11 02:28 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
You were gonna be sent to sleep with da fish if you didnt buy it?
Re: Stock stroke 360 on the dyno [Re: domingo] #949300
03/15/11 12:10 AM
03/15/11 12:10 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
thank guys next time I will buy am R3 block, I will leave the bore at 3.900 to have thicker wall.
Re: Stock stroke 360 on the dyno [Re: cbarracuda] #949301
03/15/11 01:18 AM
03/15/11 01:18 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
No need to be sarcastic Carlos. Besides your 360 has a bore of 4.00" you would need to sleeve it to go down to 3,90. Heck even the 318 is just 3,91" std bore.
In the end, the extra 0,040" overbore you are thinking of will yield just an extra 8 inches on a 4" stroke crank motor.
That should amount to an extra 10hp - 15hp on your w2 motor at the most. Thats if your cylinder walls are nice and thick at the thrust side.
If you think that will give you the extra edge that you need to go win races, then go for it.
Re: Stock stroke 360 on the dyno [Re: domingo] #949302
03/15/11 09:21 AM
03/15/11 09:21 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Well after testing yesterday morning I was able to try a few things that may be of some interest to some. The air quality was very good yesterday with the correction factor hovering at about 1.00 which is rare. Usually the STP correction factor is anywhere from 1.025-1.05
Anyways I started with the four hole Wilson and power was 427-428 @ 5900-6000rpm with torque in the 435-437 ft/lb range with excellent consistency from pull to pull. Jetting wound up @ 80-85 with the customers 750 Proform. Timing was 35 total and not changed. Just to satisfy my curiosity I removed the electric water pump and installed the customer's water pump with a single v belt. Torque was unaffected but power was now down about 7-8 hp at the very top of the RPM range. The last 2 tests were to verify power output minus the spacer and electric water pump. Torque was solidly up into the 440 lb/ft range with horsepower unaffected and still hanging @ 420-421. The no spacer pull's averages were actually 1 hp and 1.5 ft/lbs better over the entire 3500 rpm-6000 rpm span. I do not have a scanner at the shop so maybe I can scan and post the sheets tonight. I will have another stock stroke 360 with ported EQ Magnums on the dyno soon-it will be very interesting to see how it compares. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Stock stroke 360 on the dyno [Re: RAMM] #949303
03/15/11 09:27 AM
03/15/11 09:27 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Thank you.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Stock stroke 360 on the dyno [Re: Rapid340] #949304
03/15/11 11:24 AM
03/15/11 11:24 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
1.2 ft-lb/cid is pretty nice for a simple, low tech street motor...
Re: Stock stroke 360 on the dyno [Re: patrick] #949305
03/15/11 12:03 PM
03/15/11 12:03 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I think this has been a very interesting read. And, an impressive motor. I have new respect for that Voodoo grind, I'll tell ya! Like a good book, can't wait to see what the EQ-headed 360 is all about, since I'm going that way with a 408 soon.
This "street" motor, with the right converter and traction would be deep in the 11's while able to be driven both ways...
Thanks RAMM
Re: Stock stroke 360 on the dyno [Re: cudadoug] #949306
03/15/11 12:42 PM
03/15/11 12:42 PM
RAMM Offline OP
RAMM  Offline OP
Thanks for the thanks. I am quite hopeful that the EQ headed 367 will make quite a bit more steam than this mild example-but--- you never really know until you do it. Sometimes less really is more. J.Rob
Re: Stock stroke 360 on the dyno [Re: RAMM] #949307
03/15/11 01:31 PM
03/15/11 01:31 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Depending on how you prepped the EQ heads and camshaft, I think they may surpirse some people here.
RIP Monte Smith
Re: Stock stroke 360 on the dyno [Re: CompWedgeEngines] #949308
03/15/11 02:19 PM
03/15/11 02:19 PM
cudadoug Offline
cudadoug  Offline
I would agree. Although we're not done with them, the EQ's I have flow VERY WELL below .550 and very near the RHS heads on our bracket car above .550.
Re: Stock stroke 360 on the dyno [Re: kielbasa] #949309
03/30/11 11:55 PM
03/30/11 11:55 PM
mesa arizona
moturbopar Offline
moturbopar  Offline
mesa arizona
So how do you think this engine would have done with the 268/276 voodoo cam?
Re: Stock stroke 360 on the dyno [Re: RAMM] #1978836
12/29/15 08:28 PM
12/29/15 08:28 PM
South Australia
Retroboy Offline
Retroboy  Offline
South Australia
Howdy I know this is an old post but it's appeared on my computor at the perfect time. I have a vintage front engine dragster for a bit of 1/8th mile fun and I just lost lobes off my old ST21 RB camshaft and subsequent damage. My 360 is identical to this engine - valves heads etc except I have KB 190 pistons so it has a little more compression. I put the lower set of torque numbers in to a decent racing simulator and this basic lazy combo will run 5.60's in my car. Thanks you've made Cam selection easy for me. Cheers
Re: Stock stroke 360 on the dyno [Re: RAMM] #1978971
12/29/15 11:27 PM
12/29/15 11:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Impressive! I have almost the exact same built going in to a 2100 lb street rod with 3.55 gearing - 727 trans with 3000 stall convertor. Can I get it in the 12's?
Fastest 300
Re: Stock stroke 360 on the dyno [Re: Crizila] #1979525
12/30/15 06:51 PM
12/30/15 06:51 PM
South Australia
Retroboy Offline
Retroboy  Offline
South Australia
Easy
Page 3 of 3 1 2 3
