hot starter
#197851
01/19/09 09:34 AM
01/19/09 09:34 AM
Posts: 129 wisconsin usa
moretork03
wisconsin usa
I have a 7o cuda with 528 stroker with 2 1/8 inch headers. Starter turns motor fine when its cool but after the motor runs it will barely turn it over until it sits for about a 1/2 hr.whats the cure? Do I need a new starter, specialty starter, shield or ? Thanks for any feed back
Re: hot starter
[Re: moretork03]
#197854
01/19/09 11:25 AM
01/19/09 11:25 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Go with the mini or shield the starter with sheet metal, anything to get the starter motor away from heat. My guess is that the exhaust system is too close to the starter. This is a common problem on front wheel drive cars with the reduced engine compartment space. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: hot starter
[Re: moretork03]
#197856
01/19/09 12:12 PM
01/19/09 12:12 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Curious what your running for your initial and total timing?
If you have to have that gear reduction sound, another option may be to wrap the headers that are in close proximity to the starter with that heat reflective insulation. I had to wrap one of my torsion bars and my speedometer cable with some because my 2 inch TTI's came close to them. It's pretty amazing stuff.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
