hot starter #197851
01/19/09 09:34 AM
01/19/09 09:34 AM
wisconsin usa
moretork03 Offline OP
wisconsin usa
I have a 7o cuda with 528 stroker with 2 1/8 inch headers. Starter turns motor fine when its cool but after the motor runs it will barely turn it over until it sits for about a 1/2 hr.whats the cure? Do I need a new starter, specialty starter, shield or ?
Thanks for any feed back
Re: hot starter [Re: moretork03] #197852
01/19/09 10:50 AM
01/19/09 10:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sometimes timing advanced a little to far can cause this as can a heat soaked starter. You could go to a mini starter to get it away from the exhaust. Here's some info from the tech archives. http://www.moparts.org/Tech/Archive/elec/1.html
Re: hot starter [Re: moretork03] #197853
01/19/09 11:17 AM
01/19/09 11:17 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Yes, go with a mini.
Re: hot starter [Re: moretork03] #197854
01/19/09 11:25 AM
01/19/09 11:25 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Go with the mini or shield the starter with sheet metal, anything to get the starter motor away from heat. My guess is that the exhaust system is too close to the starter. This is a common problem on front wheel drive cars with the reduced engine compartment space.
Craig
Re: hot starter [Re: denfireguy] #197855
01/19/09 11:30 AM
01/19/09 11:30 AM
Re: hot starter [Re: moretork03] #197856
01/19/09 12:12 PM
01/19/09 12:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Curious what your running for your initial and total timing?
If you have to have that gear reduction sound, another option may be to wrap the headers that are in close proximity to the starter with that heat reflective insulation. I had to wrap one of my torsion bars and my speedometer cable with some because my 2 inch TTI's came close to them. It's pretty amazing stuff.
