Cylander wall thickness "update"
#1978047
12/28/15 07:21 PM
12/28/15 07:21 PM
dartman366
Mt. Vernon, Ohio
I know somewhere on this forum this has been discussed before but for the life of me I don't remember where, so here go's,,I know thicker is better but what would be acceptable for minimum thrust side thickness after boring/honing to the size needed, 400 block out to a 4.375 bore.
Re: Cylander wall thickness
[Re: dartman366]
#1978089
12/28/15 08:22 PM
12/28/15 08:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill.. I have heard of guys running .100 wall.. myself I would like .120 or better.. its real hard to find a factory production block with better than .120 when its cleaned up EDIT my mega block had .200 on basically all cylinders with a 4.5 bore(I wasnt going 4.5 but I did have it sonic checked... 64 readings per cyl... that was $75)
[Re: MR_P_BODY]
#1978161
12/28/15 10:09 PM
12/28/15 10:09 PM
dartman366
Mt. Vernon, Ohio
Bill.. I have heard of guys running .100 wall.. myself I would like .120 or better.. its real hard to find a factory production block with better than .120 when its cleaned up EDIT my mega block had .200 on basically all cylinders with a 4.5 bore(I wasnt going 4.5 but I did have it sonic checked... 64 readings per cyl... that was $75) Talked to my machinist today, he has one block checked and the other will be done in the morning and will pick them up in the afternoon,,sounds like mine are going to be real good then, at least the first one.
[Re: dartman366]
#1978214
12/28/15 11:20 PM
12/28/15 11:20 PM
Posts: 595 Nashville, Tennessee
Tempest
Just my $.02.
On another make I had a 715 HP stock block motor, did not know it at the time but the block had core shift. It was only a +.030" over bore. It came apart in a big way around 7,000 few months later. Measuring some of the block after, thrust side of the #1 cylinder was .080", the other was .300+". Basically anything that moved was ruined. Roller cam bent, roller lifters, valves hit pistons, crank bent, even bent snout on ATI balancer.
I will never do another motor without sonic checking. Last one I did was .250" and I still filled it.
[Re: Tempest]
#1978230
12/28/15 11:38 PM
12/28/15 11:38 PM
dartman366
Mt. Vernon, Ohio
Just my $.02.
I will never do another motor without sonic checking. Last one I did was .250" and I still filled it. having the sonic numbers will help me decide which block I will use, be nice if the second one is as good as the first.
[Re: B G Racing]
#1978480
12/29/15 12:29 PM
12/29/15 12:29 PM
BradH
We generally consider anything above .180 on the thrust sides at finish bore a good block... What is your minimum acceptable thickness for a NON-thrust measurement?
[Re: BradH]
#1978503
12/29/15 12:57 PM
12/29/15 12:57 PM
MR_P_BODY
We generally consider anything above .180 on the thrust sides at finish bore a good block... What is your minimum acceptable thickness for a NON-thrust measurement? I can say that every cyl that has cracked on my stuff has been on the NON thrust side.. every one.. they varied from .125 to .160.. that was 5 cyls on multiple blocks(all 340 blocks at 4.070 bores)
[Re: dartman366]
#1978765
12/29/15 06:42 PM
12/29/15 06:42 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We like to see minimal .180 all around but have used blocks at .160 on non thrust sides.Depending on the build and where the cylinder is thin we usually do a short fill. We haven't had much luck with lottery tickets.
Re: Cylander wall thickness "update"
[Re: B G Racing]
#1978904
12/29/15 10:00 PM
12/29/15 10:00 PM
dartman366
Mt. Vernon, Ohio
had two blocks one was a 1975 the other is a 1976 both came in with the numbers solidly in the .310-.320 range had a spot here and there that was in the mid 200 range worse being 245, and a couple around .260-.280,,95% are .300 or better.
[Re: dartman366]
#1979113
12/30/15 01:38 AM
12/30/15 01:38 AM
Posts: 43,272 Bend,OR USA
Cab_Burge
[Re: B G Racing]
#1979236
12/30/15 12:04 PM
12/30/15 12:04 PM
dartman366
Mt. Vernon, Ohio
That's great we usually only see those numbers on the 71 to 73 blocks.How many checks are you doing for each cylinder?Usually #1,#2,#7 and#8 non thrust to the front and back of those cylinders come up thin on those 74 and later blocks. looking at the numbers the front and back numbers are consistantly a little thinner mostly in the mid to upper .200 range, when he checks each bore he will do 4 steps on the thrust and non thrust side and 3 on the front and back of each cylander.
[Re: Cab_Burge]
#1979239
12/30/15 12:10 PM
12/30/15 12:10 PM
dartman366
Mt. Vernon, Ohio
I said somthing to him about doing a half fill and he promptly told me to not waste my time and money and that blocks like that don't need it besides he is not a proponant of using filler because of thermal issues in the cylander.
