Page 1 of 3 1 2 3
Cylander wall thickness "update" #1978047
12/28/15 07:21 PM
12/28/15 07:21 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
I know somewhere on this forum this has been discussed before but for the life of me I don't remember where, so here go's,,I know thicker is better but what would be acceptable for minimum thrust side thickness after boring/honing to the size needed, 400 block out to a 4.375 bore.
Re: Cylander wall thickness [Re: dartman366] #1978075
12/28/15 08:01 PM
12/28/15 08:01 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
The general rule I know is .200" minimum for thrust sides.
Re: Cylander wall thickness [Re: dartman366] #1978089
12/28/15 08:22 PM
12/28/15 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill.. I have heard of guys running .100 wall.. myself
I would like .120 or better.. its real hard to find a
factory production block with better than .120 when its
cleaned up
EDIT
my mega block had .200 on basically all cylinders with
a 4.5 bore(I wasnt going 4.5 but I did have it sonic
checked... 64 readings per cyl... that was $75)
wave
Re: Cylander wall thickness [Re: MR_P_BODY] #1978161
12/28/15 10:09 PM
12/28/15 10:09 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
cleaned up
EDIT
wave
Talked to my machinist today, he has one block checked and the other will be done in the morning and will pick them up in the afternoon,,sounds like mine are going to be real good then, at least the first one. thumbs
Re: Cylander wall thickness [Re: dartman366] #1978214
12/28/15 11:20 PM
12/28/15 11:20 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Just my $.02.
On another make I had a 715 HP stock block motor, did not know it at the time but the block had core shift. It was only a +.030" over bore. It came apart in a big way around 7,000 few months later. Measuring some of the block after, thrust side of the #1 cylinder was .080", the other was .300+". Basically anything that moved was ruined. Roller cam bent, roller lifters, valves hit pistons, crank bent, even bent snout on ATI balancer.
I will never do another motor without sonic checking. Last one I did was .250" and I still filled it.
Re: Cylander wall thickness [Re: Tempest] #1978230
12/28/15 11:38 PM
12/28/15 11:38 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Originally Posted By Tempest
Just my $.02.
having the sonic numbers will help me decide which block I will use, be nice if the second one is as good as the first.
Re: Cylander wall thickness [Re: dartman366] #1978356
12/29/15 01:47 AM
12/29/15 01:47 AM
I like to see .150 minimum after boring and honing on the major thrust side, I have ran blocks that had .120 on the minor thrust side with no failures with .150 on the major thrust sides, yet luck work Thicker is way better thumbs
Re: Cylander wall thickness [Re: Cab_Burge] #1978369
12/29/15 02:16 AM
12/29/15 02:16 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I posted some data on two RB blocks I checked HERE. You may find it of interest... scope
Re: Cylander wall thickness [Re: dartman366] #1978460
12/29/15 11:33 AM
12/29/15 11:33 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We generally consider anything above .180 on the thrust sides at finish bore a good block.Have we used block with less,yes but not for max performance use.
Re: Cylander wall thickness [Re: B G Racing] #1978480
12/29/15 12:29 PM
12/29/15 12:29 PM
BradH Offline
BradH  Offline
Originally Posted By B G Racing
We generally consider anything above .180 on the thrust sides at finish bore a good block...
What is your minimum acceptable thickness for a NON-thrust measurement?
Re: Cylander wall thickness [Re: BradH] #1978503
12/29/15 12:57 PM
12/29/15 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I can say that every cyl that has cracked on my stuff
has been on the NON thrust side.. every one.. they varied
from .125 to .160.. that was 5 cyls on multiple blocks(all
340 blocks at 4.070 bores)
wave
Re: Cylander wall thickness [Re: MR_P_BODY] #1978592
12/29/15 02:51 PM
12/29/15 02:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have one that`s at .118 non thrust 7000`+ r`s 14 years later.........better but a lottery ticket....... work
Re: Cylander wall thickness [Re: dartman366] #1978765
12/29/15 06:42 PM
12/29/15 06:42 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We like to see minimal .180 all around but have used blocks at .160 on non thrust sides.Depending on the build and where the cylinder is thin we usually do a short fill.
We haven't had much luck with lottery tickets. shruggy
Re: Cylander wall thickness "update" [Re: B G Racing] #1978904
12/29/15 10:00 PM
12/29/15 10:00 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
had two blocks one was a 1975 the other is a 1976 both came in with the numbers solidly in the .310-.320 range had a spot here and there that was in the mid 200 range worse being 245, and a couple around .260-.280,,95% are .300 or better.
Re: Cylander wall thickness "update" [Re: dartman366] #1978935
12/29/15 10:40 PM
12/29/15 10:40 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Yes!!!! I will never build another engine blind again. QC at the Trenton plant back in the day was a joke at best and that is an understatement at best. Especially those 76-79 ultra ultra thin wall cast 400/440 blocks🤓
Re: Cylander wall thickness "update" [Re: dartman366] #1979113
12/30/15 01:38 AM
12/30/15 01:38 AM
Dude, you got really lucky upbow Maybe it is time for you to buy a lottery ticket while your luck is in town whistling grin shruggy AKA, those are stout block castings thumbs Flog the dog snot out of both of them hammer thumbs devil
Re: Cylander wall thickness "update" [Re: dartman366] #1979206
12/30/15 09:59 AM
12/30/15 09:59 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That's great we usually only see those numbers on the 71 to 73 blocks.How many checks are you doing for each cylinder?Usually #1,#2,#7 and#8 non thrust to the front and back of those cylinders come up thin on those 74 and later blocks.
Re: Cylander wall thickness "update" [Re: dartman366] #1979207
12/30/15 10:15 AM
12/30/15 10:15 AM
P
Porter67 Offline
Porter67  Offline
P
Do you guys factor in weather your checking a oem block vs a race block of better material in whats a go or no go block?
Re: Cylander wall thickness "update" [Re: B G Racing] #1979236
12/30/15 12:04 PM
12/30/15 12:04 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
looking at the numbers the front and back numbers are consistantly a little thinner mostly in the mid to upper .200 range, when he checks each bore he will do 4 steps on the thrust and non thrust side and 3 on the front and back of each cylander.
Re: Cylander wall thickness "update" [Re: Cab_Burge] #1979239
12/30/15 12:10 PM
12/30/15 12:10 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I said somthing to him about doing a half fill and he promptly told me to not waste my time and money and that blocks like that don't need it besides he is not a proponant of using filler because of thermal issues in the cylander.
Page 1 of 3 1 2 3
