Difference between a 74 Duster 4 speed and 71 Duster 4 speed #1978056
12/28/15 07:37 PM
12/28/15 07:37 PM
Minnesota
70dartswinger Offline OP
Minnesota
What is required to put a 74 Duster 4 speed in a 71 Duster 4 speed car?
I am wondering if there is a difference in bell housings, pedals, clutch.
Is the transmission identical?
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1978066
12/28/15 07:49 PM
12/28/15 07:49 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If its a 4 speed to 4 speed its a direct bolt in...
Make sure its a 4 speed and not a 3 speed OD. That will require a bell housing change. twocents
I'm sure some know it all will reply to tell us it won't fit... eyes
...FAFO...
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: skicker] #1978069
12/28/15 07:52 PM
12/28/15 07:52 PM
Minnesota
Minnesota
Thanks. I don't know if the 74 is a 3 speed overdrive.
I do know that both fender tags say D21.
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1978073
12/28/15 07:59 PM
12/28/15 07:59 PM
CA
crackedback Offline
crackedback  Offline
CA
Get the trans and bellhousing from the 74 if available. Should solve the retainer bearing size issue.
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1978149
12/28/15 09:37 PM
12/28/15 09:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Brewers shows the pedal assemblies as different, dunno what is different or if they are swappable as an assembly. Might want to talk to them and see if they can help.
http://www.brewersperformance.com/contact.htm
Don't be the exception.
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1978348
12/29/15 01:39 AM
12/29/15 01:39 AM
Mopar change the gear ratios in the B and E bodys in 1971 to match the AAR Cuda and T/A Challenger ratios, not sure about the A bodies though confused They also changed the synrcho assemblies in either 1969, 1970 or 1971 as well as the side covers in 1971 to the GM style shock. I would pull both side covers and take a good hard look at all the gears in both boxes and go from thier scope twocents Take the better box thumbs
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1978357
12/29/15 01:57 AM
12/29/15 01:57 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
AS far as I know the OD came out in 1975, so a true 1974 4 speed should be a normal 1:1 box.
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: Jim_Lusk] #1978582
12/29/15 02:40 PM
12/29/15 02:40 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
There were some 75 1:1 3.09 low gear trans put in cars, several I have had used the 5.125" retainer also, fwiw.
A833 4-speeds, parts & services
Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed [Re: 70dartswinger] #1979266
12/30/15 12:59 PM
12/30/15 12:59 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I went thru a 73 A-body 4 speed back in 2010. It was a "close-ratio" gearset. IIRC, that started in 73. Gears were hard to find. Repro gears are available for the 71 trans you have access to. It's cheaper to rebuild than a later trans.
Personally, I'd get both and use the best from each. The sidecover/levers may be better from the newer one.
