Re: Difference between a 74 Duster 4 speed and 71 Duster 4 speed
[Re: 70dartswinger]
#1978066
12/28/15 07:49 PM
12/28/15 07:49 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
If its a 4 speed to 4 speed its a direct bolt in... Make sure its a 4 speed and not a 3 speed OD. That will require a bell housing change. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I'm sure some know it all will reply to tell us it won't fit... ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif)
...FAFO...
[Re: 70dartswinger]
#1978149
12/28/15 09:37 PM
12/28/15 09:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Brewers shows the pedal assemblies as different, dunno what is different or if they are swappable as an assembly. Might want to talk to them and see if they can help. http://www.brewersperformance.com/contact.htm
[Re: Jim_Lusk]
#1978582
12/29/15 02:40 PM
12/29/15 02:40 PM
Posts: 768 Ohio
Dan Brewer
Ohio
AS far as I know the OD came out in 1975, so a true 1974 4 speed should be a normal 1:1 box. There were some 75 1:1 3.09 low gear trans put in cars, several I have had used the 5.125" retainer also, fwiw.
[Re: 70dartswinger]
#1979266
12/30/15 12:59 PM
12/30/15 12:59 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
I went thru a 73 A-body 4 speed back in 2010. It was a "close-ratio" gearset. IIRC, that started in 73. Gears were hard to find. Repro gears are available for the 71 trans you have access to. It's cheaper to rebuild than a later trans.
Personally, I'd get both and use the best from each. The sidecover/levers may be better from the newer one.
