distributing hitch #1970392
12/15/15 08:45 PM
12/15/15 08:45 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
http://www.harborfreight.com/10-000-lb-capacity-weight-distributing-hitch-system.html
Anyone ever use one here? Seems to be good rating on it.
My question is can you backup and turn in a 90 degree angle with it or is it something that has to be un-hook?
Re: distributing hitch [Re: racerx] #1970439
12/15/15 09:53 PM
12/15/15 09:53 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Looks similar to the one I got years ago from Reese hitch. Still have it and I have no problems turning at 90 degrees.
Re: distributing hitch [Re: 68dodge] #1970469
12/15/15 10:30 PM
12/15/15 10:30 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use a 14K WD hitch and have never had issues. I used to use a Reese type 10K like the knock-off HF one but had to go bigger for my heavier trailer. I was wondering about the new "silent" hitch, anyone ever use one of these? shruggy
http://www.thehitchstore.com/silent-weig...0becf304d591a2c
JB Rhinehart, Realist
A-Body's RULE!
Re: distributing hitch [Re: racerx] #1970656
12/16/15 02:45 AM
12/16/15 02:45 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Check on ebay for a Reese hitch. I got mine for about the same money and it is was much nicer then the HF one. I got it brand new in the box.
Re: distributing hitch [Re: racerx] #1970710
12/16/15 09:07 AM
12/16/15 09:07 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs that's an good ideal thumbs I'll check it out.
Re: distributing hitch [Re: 68dodge] #1970711
12/16/15 09:10 AM
12/16/15 09:10 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is that backing it up? Cause that's what it will take to put my car/trailer into my garage. wave
Re: distributing hitch [Re: racerx] #1971290
12/17/15 03:34 AM
12/17/15 03:34 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Guess that depends on how close that 90 has to be made. For the truck to be able to push a trailer back at a full on 90 degrees is probably nearly impossible off a bumper hitch. You might get the trailer at 90 degrees to the truck, but the front end of the truck won't come around quick enough to push the trailer back in to maintain the 90. I foresee a lot of bent stuff, often.
If you really need to do a 90 right outside your garage, you probably need a 5th wheel or a goose neck trailer, they turn sharper then a bumper hitch will. Gene
Re: distributing hitch [Re: poorboy] #1971336
12/17/15 09:21 AM
12/17/15 09:21 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Actually it's not a full 90 but close and I do have the scares to prove it.....Lol people ask how I back this car/trailer in the garage and I just say know-how. grin
Re: distributing hitch [Re: racerx] #1977039
12/27/15 12:25 PM
12/27/15 12:25 PM
NC
440Jim Offline
440Jim  Offline
NC
I would prefer a hitch with steel made in the USA, like Reese or Curt. I bought a Curt from www.thehitchstore.com
Re: distributing hitch [Re: racerx] #1977333
12/27/15 07:22 PM
12/27/15 07:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the link......Jim thumbs
