Re: distributing hitch
[Re: racerx]
#1971290
12/17/15 03:34 AM
12/17/15 03:34 AM
Posts: 10,586 Freeport IL USA
poorboy
Freeport IL USA
Looks similar to the one I got years ago from Reese hitch. Still have it and I have no problems turning at 90 degrees. Is that backing it up? Cause that's what it will take to put my car/trailer into my garage. Guess that depends on how close that 90 has to be made. For the truck to be able to push a trailer back at a full on 90 degrees is probably nearly impossible off a bumper hitch. You might get the trailer at 90 degrees to the truck, but the front end of the truck won't come around quick enough to push the trailer back in to maintain the 90. I foresee a lot of bent stuff, often. If you really need to do a 90 right outside your garage, you probably need a 5th wheel or a goose neck trailer, they turn sharper then a bumper hitch will. Gene
