70 Hemi Trans Cooler #1975058
12/23/15 11:15 AM
12/23/15 11:15 AM
MI
70ta340 Offline OP
70ta340  Offline OP
MI
Does anyone know if a 70 Hemi B-Body automatic come with a trans cooler? I know they did for 68 and 69, but I've seen some 70's with and some without. Does the axle ratio determine if it should be included? I'm just trying to determine which is correct.
Thanks, Bill
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975062
12/23/15 11:35 AM
12/23/15 11:35 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
General rule - Yes, your 70 HEMI B-body automatic should have a external trans cooler. Although it's possible some were made without???
Tom
68 Charger
70 Cuda
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975111
12/23/15 01:40 PM
12/23/15 01:40 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
like FC7 said, it should have
it wasn't dependent on axle ratio
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975172
12/23/15 03:21 PM
12/23/15 03:21 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Even my 3.23 gear 70 Hemi Challenger and 70 Hemi Charger had a cooler so I think it's safe to say you would have one
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975219
12/23/15 04:49 PM
12/23/15 04:49 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
Reproductions are available, for a great deal check with our own Terry McCann.
The 66-70 B-bodies were all pretty similar with differences in the mounting brackets.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975290
12/23/15 06:48 PM
12/23/15 06:48 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
Thanks, Bill
Yes they all came with coolers. Gear doesn't matter
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1975328
12/23/15 08:07 PM
12/23/15 08:07 PM
MI
70ta340 Offline OP
70ta340  Offline OP
MI
Thank you for the feedback!
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1976911
12/27/15 02:02 AM
12/27/15 02:02 AM
Detroit Michigan
1971HEMICUDA Offline
Detroit Michigan
70/71 E Bodies and 1971 B Bodies take the same automatic transmission cooler, that being the rectangle cooler. 66 to 70 B Bodies take another style of automatic Transmission Cooler the square type that was posted by BS27 with a picture above. The differences between the 66-70 would be in the body styles with different brackets on the square automatic coolers. Not sure how many different brackets there are for B Bodies. I would say a set of brackets for 66/67 B Bodies, then 68,69,70 B Bodies, and a different set of brackets for a Daytona and a Superbird and then maybe different brackets for 68,69,70 Chargers.
Maybe some one knows if a 1968 Hemi A Body with an automatic got a Hemi automatic transmission cooler.
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1976957
12/27/15 03:12 AM
12/27/15 03:12 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
They are not all the same. 66-67 coolers had straight fins and 68-70 had wavy fins........so it's more than just brackets that can be different
Re: 70 Hemi Trans Cooler [Re: 1971HEMICUDA] #1977011
12/27/15 11:05 AM
12/27/15 11:05 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Originally Posted By 1971HEMICUDA
Maybe some knows if a 1968 Hemi A Body with an automatic got a Hemi automatic transmission cooler.
Yes I would like to know that as well.
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1977215
12/27/15 04:37 PM
12/27/15 04:37 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The various cooler brackets used.
Inner rad support bracket ( on right )is the same for all.
I have seen some 67's with the 68 style vertical rad support bracket.
Should read Daytona and 68-70 Charger R/T
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1977236
12/27/15 05:04 PM
12/27/15 05:04 PM
WA
tman Offline
tman  Offline
WA
Does someone sell the brackets if you just wanted to add a cooler for an Ebody? Looks like you would need the cooler lines too.
Re: 70 Hemi Trans Cooler [Re: 70ta340] #1981135
01/01/16 03:32 PM
01/01/16 03:32 PM
Manitoba, Canada
fjmg Offline
fjmg  Offline
Manitoba, Canada
Just as an FYI, the pass. side mount on the 68-69 hemi auto chargers were not the same as a daytona. Since the grill support on the 69 was removed to install daytona front end, there is nothing to bolt to, the cooler would flop in the wind.
On the few hemi auto daytonas that I have seen, creative bent a strip of approx. 1" wide sheet metal and crudely welded it to the underside of the top rad crossmember, this strip hung down beside the pass. Side of the cooler and was fastened to the cooler where the 68-69 oem bracket was secured.
Re: 70 Hemi Trans Cooler [Re: tman] #1981925
01/02/16 01:18 PM
01/02/16 01:18 PM
California
biggE Offline
biggE  Offline
California
'70-'71 ebody cooler does not need separate brackets. The unit mounts as is to the car.
Re: 70 Hemi Trans Cooler [Re: 70ta340] #2361595
08/29/17 10:39 AM
08/29/17 10:39 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Did some of the very early Hemi E-bodies get built without this trans cooler?
Tom
68 Charger
70 Cuda
Re: 70 Hemi Trans Cooler [Re: FC7cuda] #2361615
08/29/17 11:22 AM
08/29/17 11:22 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The only documented Hemi E-body that came without a cooler I am aware of, is the red/red 1970 HemiCuda convertible that Suloff owned in its early years.
Not saying there may not have been others.
