Rim Screws #1974822
12/22/15 10:47 PM
12/22/15 10:47 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Can you run rim screws when there is a slight clearance between the screw and the hole?
Alan Jones
Re: Rim Screws [Re: LA360] #1974830
12/22/15 10:55 PM
12/22/15 10:55 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have a few that aren't bottomed out. Been like that for years. Haven't had any problem's.
Re: Rim Screws [Re: LA360] #1974844
12/22/15 11:18 PM
12/22/15 11:18 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Ideally you want them secured in the rim, purpose is to "pin" the tire to the rim, not so much as to bolt the tire to the rim, thats generally when you have problems.
Re: Rim Screws [Re: LA360] #1974846
12/22/15 11:20 PM
12/22/15 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I screw to the rim.. the screw screws/pokes
into the tire
wave
Re: Rim Screws [Re: Jerry Kathe] #1974857
12/22/15 11:33 PM
12/22/15 11:33 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I can relate to your question, my old rims had a small lip at the edge that the head of the screw hit first. It never cause a problem just looked like the screws were loose. 40 years ago I had a set of mag wheels that used large pop rivets instead of screws, they stuck through the rim about a 1/4" . When the slick was removed the rivets had imbedded into the bead and held just like a screw . No broken screws, no screws unscrewing and no fighting trying to screw the screws into the tire bead. Just a thought of something different.
Re: Rim Screws [Re: rowin4] #1974901
12/23/15 12:58 AM
12/23/15 12:58 AM
LA360 Offline OP
LA360  Offline OP
The rims my friend has have been drilled so the Moroso screws slide in, rather than being around 0.040" smaller than the screw itself. I'm wondering if I should try and find some slightly larger OD screws
Alan Jones
Re: Rim Screws [Re: LA360] #1974914
12/23/15 01:23 AM
12/23/15 01:23 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, that is what you should do. Screws should "bit" in to the wheels and just protrude in to the rubber bead area.
Fastest 300
Re: Rim Screws [Re: LA360] #1975034
12/23/15 07:21 AM
12/23/15 07:21 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when i was screwing my rims i used Tek screws & put them in using the cordless drill. easy to install, easy to remove. I gave up screwing my rims a few years back. i just watch a mark i put on the rubber move on the first meeting, swap sides so the mark moves back, but it never gets right back before those slicks are toast. thats doing 1.29 60's.
Re: Rim Screws [Re: rebel] #1975170
12/23/15 03:18 PM
12/23/15 03:18 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
my screw holes were worn out from changing slicks several times, I hit the hole with a blunt end punch and it made the hole smaller/tighter. this was with aluminum wheels
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Rim Screws [Re: LA360] #1975280
12/23/15 06:24 PM
12/23/15 06:24 PM
I've been told by the old Firstone race tire rep to not bottom the rim screws down flush and leave them that way, he said to bottom them and then back them out 1/32 to 1/16 turn or so. When I switch to M/T tires they verify to do that also shruggy That was over twenty years ago so things may be different now. Contact the tire company your using and let us know what they say to do now work
Re: Rim Screws [Re: Cab_Burge] #1975545
12/24/15 04:55 AM
12/24/15 04:55 AM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
I ran Firestone slicks for a couple of decades, then Phoenix. The bead was/is so laden with steel, the moroso screws thread into the tire. The original sheet thread in the rims, formed by the screws, went away 20 pairs of tires ago. I've not had any problems. twocents
