Rim Screws
#1974822
12/22/15 10:47 PM
12/22/15 10:47 PM
Posts: 6,149 Melbourne , Australia
LA360
Can you run rim screws when there is a slight clearance between the screw and the hole?
Alan Jones
Re: Rim Screws
[Re: Jerry Kathe]
#1974857
12/22/15 11:33 PM
12/22/15 11:33 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I can relate to your question, my old rims had a small lip at the edge that the head of the screw hit first. It never cause a problem just looked like the screws were loose. 40 years ago I had a set of mag wheels that used large pop rivets instead of screws, they stuck through the rim about a 1/4" . When the slick was removed the rivets had imbedded into the bead and held just like a screw . No broken screws, no screws unscrewing and no fighting trying to screw the screws into the tire bead. Just a thought of something different.
Re: Rim Screws
[Re: rowin4]
#1974901
12/23/15 12:58 AM
12/23/15 12:58 AM
LA360
The rims my friend has have been drilled so the Moroso screws slide in, rather than being around 0.040" smaller than the screw itself. I'm wondering if I should try and find some slightly larger OD screws
Alan Jones
Re: Rim Screws
[Re: LA360]
#1974914
12/23/15 01:23 AM
12/23/15 01:23 AM
Posts: 7,506 Az
Crizila
Az
The rims my friend has have been drilled so the Moroso screws slide in, rather than being around 0.040" smaller than the screw itself. I'm wondering if I should try and find some slightly larger OD screws Yes, that is what you should do. Screws should "bit" in to the wheels and just protrude in to the rubber bead area.
Fastest 300
Re: Rim Screws
[Re: rebel]
#1975170
12/23/15 03:18 PM
12/23/15 03:18 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, my screw holes were worn out from changing slicks several times, I hit the hole with a blunt end punch and it made the hole smaller/tighter. this was with aluminum wheels gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
