fox adjustable shocks settings.. #1974324
12/22/15 03:35 AM
12/22/15 03:35 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
just installed my fox adjustable shocks, car drives great with all the other goodies i mentioned in this section, however its a bit bouncy at low speeds and cruising.. anyone run these that can chime in on how to set them.. i have a 70 challenger thanks.
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
Re: fox adjustable shocks settings.. [Re: jaque] #1974326
12/22/15 03:56 AM
12/22/15 03:56 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Start cranking them up till the bounce settles. The adjustability is for rebound.
Re: fox adjustable shocks settings.. [Re: jaque] #1974329
12/22/15 04:00 AM
12/22/15 04:00 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
how do you crank them up?? righty tight, lefty loose??thank you.
Re: fox adjustable shocks settings.. [Re: jaque] #1974343
12/22/15 04:28 AM
12/22/15 04:28 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I haven't seen my shocks in months because my Dart has been at the shop; however, I believe righty tighty makes the rebound stiffer. I believe there should be an arrow on the top of the red knob that indicates which way is stiffer. Just make sure to count clicks so both sides are set the same (if that's what you want).
Re: fox adjustable shocks settings.. [Re: jaque] #1974348
12/22/15 04:34 AM
12/22/15 04:34 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
thank you for input!!!
Re: fox adjustable shocks settings.. [Re: jaque] #1974601
12/22/15 03:51 PM
12/22/15 03:51 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Samy is correct, righty stiffy. With a big car like yours, I'd start with the fronts about 1/2 stiff, and the rears 5 clicks from full soft, then adjust from there...
Re: fox adjustable shocks settings.. [Re: jaque] #1974708
12/22/15 07:20 PM
12/22/15 07:20 PM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
awesome thanks, each seperate click is and adjustment im assuming?? they just keep on clicking.. so im going to click to lowest setting and the go up from there. ill try that out..
btw, i dig youre car and for the money its a deal, did you sell it?
Re: fox adjustable shocks settings.. [Re: jaque] #1974812
12/22/15 10:34 PM
12/22/15 10:34 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I believe there are about 35 different adjustments/clicks so probably start around 15-20 clicks stiff for the front.
Re: fox adjustable shocks settings.. [Re: jaque] #1974818
12/22/15 10:41 PM
12/22/15 10:41 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Thanks, not sold yet. I believe mine have about 25 clicks soft to firm...
Re: fox adjustable shocks settings.. [Re: Tomswheels] #1974825
12/22/15 10:51 PM
12/22/15 10:51 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Yeah, I'm not sure. Hotchkis' website says 45 rebound adjustments but that may be 25 for the front and 20 for the rear.
http://www.hotchkis.net/product/hotchkis...=286&sm=295
Re: fox adjustable shocks settings.. [Re: jaque] #1974913
12/23/15 01:21 AM
12/23/15 01:21 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
the fronts were clicked very stiif, didnt cout how many to zero out, from there i went up 11 clicks, jon said there were 22. then in the back zeroed out and went up 5 clicks, they were at least at the half way mark of the settings.. so that would explain bouncy feel. so firmer up top and softer out back and will expirement from there. just happy it drives firm and handles great!
thanks for input, ill keep thread informed on progress thanks again..
Re: fox adjustable shocks settings.. [Re: jaque] #1974969
12/23/15 02:48 AM
12/23/15 02:48 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
just wanted to chime in...i would like to know which way you guys would mount your rear shocks...i guess you can either mount your rear shocks either way...knob facing down...or knob facing up....john at hotchkis confirmed either way but i would like to hear it from some of the guys here on moparts...my thoughts are yes its way easier to adjust your shock when you mount the shock with knob facing ground but one would think all the fluid in body with gravity does not make sense...mine are mounted knob up with fluid body at rest...witch way would you guys mount them?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: fox adjustable shocks settings.. [Re: jaque] #1975011
12/23/15 04:52 AM
12/23/15 04:52 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I went upside down... No problems so far
Re: fox adjustable shocks settings.. [Re: jaque] #1975014
12/23/15 05:12 AM
12/23/15 05:12 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
me too inverted, jon said either way fine, but preference is knob facing down for easy adjustment..
Re: fox adjustable shocks settings.. [Re: jaque] #1975278
12/23/15 06:22 PM
12/23/15 06:22 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I recall my front Hotchikis shocks were at 17 clicks from soft (from a possible 22).
Been dailydriving with this setting for little over a year now.
Just yesterday I decided to tighten them up a click but noticed only a very minor improvement, so I'll probably add another click soon.
Maybe some internal valve wear is setting in.
Anyone have any input about the service intervals of these shocks?
On the rear I've got QA1 adjustables and they've got the adjuster knob on the bottom by default, so I can adjust their setting by simply reaching around the tires and turn the knob.
Re: fox adjustable shocks settings.. [Re: jaque] #1975329
12/23/15 08:11 PM
12/23/15 08:11 PM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
well they are warranted for life, so any problems youre covered..
Re: fox adjustable shocks settings.. [Re: BigBlockMopar] #1978940
12/29/15 10:45 PM
12/29/15 10:45 PM
Santa Fe Springs, CA
Jon @ Hotchkis Offline
The Fox guys estimate the lifespan to be around 100-150k miles depending on conditions.
Hotchkis Performance
8633 Sorensen Ave.
Santa Fe Springs, CA 90670
Phone: 562-907-7757 x224
Fax: 562-907-7765
Hotchkis Performance East
9075 Highway 152
Mooresville, NC 28115
704-660-3060
Re: fox adjustable shocks settings.. [Re: jaque] #1979199
12/30/15 09:33 AM
12/30/15 09:33 AM
The Netherlands
The Netherlands
Thanks for that info. I've driven about 6600 miles this year.
But on my daily commutes I encounter about 25 to 50 medium to high speedbumps and quite some brickstone roads. I wouldn't be surprised if some dimishing shock performance will occur after a few years.
Re: fox adjustable shocks settings.. [Re: Tomswheels] #1983531
01/04/16 04:56 PM
01/04/16 04:56 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I'm fairly close to this to start with the fronts a little stiffer. I'm impressed with the difference over the bilsteins. I thought the Bilsteins were excellent, but I can tell a positive difference with these.
Re: fox adjustable shocks settings.. [Re: jaque] #1983571
01/04/16 05:53 PM
01/04/16 05:53 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
While I don't have Fox shocks on my car I ended up with stiffer on the rebound on the front than the rear with my adjustable shocks.
I'm surprised that FOX gives a lifetime warranty on the shock, most of their shocks require frequent oil changes and shaft seal leaks are fairly common.
A new iron curtain drawn across the 49th parallel
