Re: Hemi K Member ???
[Re: BB70DUSTER]
#1973921
12/21/15 05:20 PM
12/21/15 05:20 PM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
The drag link is different as is the skid plate and the driver side mount.
Not sure the older b-body k-member will bolt in or bolt in and locate the engine in the right location in an e-body
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: BB70DUSTER]
#1974524
12/22/15 01:58 PM
12/22/15 01:58 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
Im hoping it will work, but may end up available if not... Anyone else know if it will work? Why not work a trade for the right one you need?
[Re: JohnRR]
#1974657
12/22/15 05:15 PM
12/22/15 05:15 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Im hoping it will work, but may end up available if not... Anyone else know if it will work? Why not work a trade for the right one you need? Im not opposed to that...
[Re: 71birdJ68]
#1974658
12/22/15 05:15 PM
12/22/15 05:15 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Yes, the engine sits different in a E body compared to the older B bodies. I know the big block does, but do you know for sure that a Hemi did also?
[Re: fastmark]
#1974756
12/22/15 09:02 PM
12/22/15 09:02 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
A true 65 Hemi k frame does not have any skid plate if my memory is correct. A 66 Hemi k frame will. I sold my 65 Hemi car so I can't look to see. I believe the one in my 65 was made by Phil Newcomb (Hemispherical Productions, or something like that...) But does not have a skid plate, has sway bar holes in the front...
