1979 D150 Maximum Wheel Size? #1973188
12/20/15 12:44 PM
12/20/15 12:44 PM
Germany
1964Polara Offline OP
Germany
I've got a 1979 D150 Truck with worn Springs at the front & rear.
What is the Maximum Wheel Diameter and Wide fitting the Fenders without rubbing. As I intend to by new rims as well I need also some guidance for Rim Wide and Backspacing. 31', 32' diameter? Even more?
Let me know what you did and maybe with photos....
Thanx
Re: 1979 D150 Maximum Wheel Size? [Re: 1964Polara] #1973407
12/20/15 07:39 PM
12/20/15 07:39 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I ran 31x10.5x15" on a 8" wide wheel on my 74 d100 club cab 2wd and it swallowed them with room to spare. Pretty sure a 10" wide wheel would not be a problem. Hope this helps.
Re: 1979 D150 Maximum Wheel Size? [Re: 1964Polara] #1974351
12/22/15 04:43 AM
12/22/15 04:43 AM
Germany
Germany
OK Do you think 32' will do also? What sort of Backspace?
Re: 1979 D150 Maximum Wheel Size? [Re: 1964Polara] #1974492
12/22/15 01:09 PM
12/22/15 01:09 PM
scratchnfotraction Offline
I ran a 32 x 11.50 x 15 on a 10" wide rim with 4.5 backspace on rim
ran 275/60/15 on same rim
I think I had a 33 x 12.50 x 15 on the rear of my stepside with that rim also.
been a while, in my 88-440 truck I have the A-body rear axle with 12" wide rim with 4.5 back space 29 x 15 x 15 M/Ts now. tubbed but in the fender.
on ALL my trucks the fronts stay with a 235/75/15 on 8" wide with 4" back space. except the 440 truck-it gets a 215/75/15 up front.
